August 29, 2026, 09:47:05 am
Hoffman Amps Forum image Author Topic: Carling SPST switch washer ??!!  (Read 4309 times)
Offline worth
« on: May 22, 2012, 12:40:20 pm »
Where can I find a VERY THIN washer with a 1/2" I.D. similar to the washers supplied with Switchcraft input jacks ? Every where I look the washers are too thick .
Offline The_Gaz
Re: Carling SPST switch washer ??!!
« Reply #1 on: May 22, 2012, 01:55:31 pm »
Where are you looking, the hardware store? It's an electronics specific part. Mouser will have them.
Offline thelonious
  • t00b n00b
« Reply #2 on: May 22, 2012, 10:07:26 pm »
I agree with The_Gaz that Mouser is probably your best choice. If you can't find it there, Small Bear sells this washer for 3PDT footswitches: http://www.smallbearelec.com/servlet/Detail?no=740 . I believe it is 1/2" ID. In either case, you had better do it as part of a larger order, or your shipping cost would be pretty exorbitant!
