September 16, 2026, 12:04:17 am
Hoffman Amps Forum image Author Topic: Jet City JCA50 low output. Troubleshooting and scratching head:(  (Read 4793 times)
Offline Marcus
I have a JCA 50 and it doesn't seem to have that much gain and the output seem too low for a 50 watt tube amp.These amps are supposed to have alot of gain. This one doen't. With the gain cranked and the volume dimed I can stand right in front of the amp. I changed all the valves and biased the power tubes to 35 ma. They were biased at 9 ma but there was no difference in volume. I poked around with my meter and didn't find any open or bad resistors. I haven't checked any voltages yet. I also haven't checked the OT but I doubt that is the ploblem(I know it could be though). One thing I did notice is the ground wire from the effects return is disconnected for some reason. Could this cause a problem if I'm not using the effects loop?
Offline LooseChange
    • Fix Your Darn Amps
Re: Jet City JCA50 low output. Troubleshooting and scratching head:(
« Reply #1 on: May 27, 2012, 06:35:27 am »
Does the low output still sound like the amp should? Did you jump the effects loop with a patch cord?
I've only had one of these in the shop. It had low output, but sounded right. The output transformer was bad and I had to replace it.
Call me Dan
www.fydamps.com
stratele52
  • Guest
« Reply #2 on: May 27, 2012, 08:18:19 am »
Check voltage is the first thing to do.
« Reply #3 on: June 06, 2012, 04:06:29 pm »
Did you find the problem with the Jet City amp?
