September 16, 2026, 08:23:52 am
Hoffman Amps Forum image Author Topic: 5879 CF vs paralleled 12A_7 CF  (Read 5324 times)
« on: June 06, 2012, 04:47:41 pm »
I played my Tweed Overdrive Special last night and it sounded really great to me. Nice amp.
Having said that, ................. I was wondering what it would sound like to use a paralleled 12A_7 with a CF instead of the 5879 and a CF.
No other reason, then curiousity & the option to control gain factors thru different 12A_7 tubes.
Anyone tried a paralleled 12A_7 with a CF before ..................... and if so, ........... how did it sound?
The 5879 is in the OD section of the TOS.
with respect, Tubenit
Offline Fresh_Start
  • noob de Lux
Re: 5879 CF vs paralleled 12A_7 CF
« Reply #1 on: June 06, 2012, 09:23:49 pm »
How about a cascode with the two triodes?   I've read that a cascode performs similarly to a pentode.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
« Reply #2 on: June 07, 2012, 03:26:05 am »
What Chip said. You'd get more gain out of the cascode.
« Reply #3 on: June 07, 2012, 07:35:44 am »
Thanks for the cascode idea.  I would use the 5879 instead of that though.
I was specifically wondering about a paralleled 12A_7 & CF.  If anyone has tried that?
Offline tonewood
« Reply #4 on: June 07, 2012, 09:47:23 am »
That 2k2 Rk seems pretty cold for paralled 12ax7s, are you planning on U7 or Y7 or were you going for a cold stage? I'd like to hear clips if you build it. Thanks.
Offline Fresh_Start
  • noob de Lux
« Reply #5 on: June 07, 2012, 11:57:13 am »
tubenit - the AX84 "Blues Preamp" has paralleled 12AU7 stages feeding the poweramp.  It's possible that someone over on that forum discussed sticking a cathode follower in there while they were developing that circuit.
Sorry for the cascode sidetrack.  My initial thought was that it would allow you to substitute different 12A_7 tubes for different gain levels, but I doubt a "universal" cascode circuit would be very useful.
With respect,
Chip
Quote from: PRR
