September 16, 2026, 06:06:26 am
Hoffman Amps Forum image Author Topic: Chassis heat?  (Read 4601 times)
Offline stratavox
Chassis heat?
« on: June 08, 2012, 06:12:16 pm »
In a 5E3 and a 5E5 build- both amps have the chassis above the tube/PT section hot to the point of not being able to keep my fingers on the chassis for more than a few minutes. Normal? TIA for your thoughts-
Re: Chassis heat?
« Reply #1 on: June 08, 2012, 06:35:30 pm »
Normal. As long as you have adequate ventilation in the back of the combo, it will function normally. (i.e.: don't stick it up against a wall)
Re: Chassis heat?
« Reply #2 on: June 08, 2012, 08:31:50 pm »
Minutes?? I've had tube amps, I didn't want to hold more than a few *seconds*. Didn't hurt them none.
Offline stratavox
Re: Chassis heat?
« Reply #3 on: June 08, 2012, 09:19:25 pm »
Folks, as always, many thanks. I appreciate your time, and input. If you should find yourself in the Pittsburgh area,
PLEASE let me know.
