September 16, 2026, 02:28:58 pm
Hoffman Amps Forum image Author Topic: PT idea, suggestion, question  (Read 5313 times)
« on: June 10, 2012, 09:03:58 am »
A lot of the topics I read have to do with B+ being too high. That's my common peeve as well. So, question first - is it possible for a transformer to put out 120 -150 mA while only having say, a 250-0-250 winding?
If it is, I wonder if Doug could stock em?  :grin:
I know you can always lower the B+ through resistors, tube rect. etc, I'm just wishing for a simple solution. Should I get 2 hats?  :laugh:
 I'm sure a lot of guys are like me, with the wall voltage being well over 120. Mine usually runs 125-127, so even a 290-0-290 ends up putting out ~430 VDC, sometimes more.
Re: PT idea, suggestion, question
« Reply #1 on: June 10, 2012, 10:12:46 pm »
230V transformers are easy to find from 50mA to 20,000mA.
Problem is finding one with a 6V winding also.
stratele52
  • Guest
« Reply #2 on: June 11, 2012, 03:37:14 am »
Resistor ; give you too much sag , tube rectifier; not enough choice
Very easy way ; some 10 volts 5 watts zener diodes like 1N5347B  less than $1 us each
On any kind of project you could need them. Also when fixing old amp working on 110 volts AC wall outlets, sometimes I use zener diode to lower B+, today wall outlet could give more than 120 AC
stratele52
  • Guest
« Reply #3 on: June 11, 2012, 03:58:22 pm »
     ..... black boxes you can put between your amp and the plug to selectively reduce voltage
Not good choice . You must not reduce heater voltage , only B+
