September 15, 2026, 01:13:56 am
Hoffman Amps Forum image Author Topic: 5E3 tone stack & PAB & midboost  (Read 9134 times)
« on: June 14, 2012, 06:54:20 am »
I don't adjust the tone stack settings very much. I am more likely to flip a switch like a midboost or a PAB to change a tone.
So, I was thinking about how to simplify a tone stack but retain the midboost & PAB.
I have not tried this yet.
Offline tonewood
Re: 5E3 tone stack & PAB & midboost
« Reply #1 on: June 18, 2012, 10:49:23 am »
Same here.
Tubenit, did you try this yet?
The 5E3 vs redrawn 5E3 ckt look different. In the altered version it looks like the input wired to the output is shorting past the bright cap making it ineffective. Am I looking at this wrong?
Offline Tyrannocaster
« Reply #2 on: June 18, 2012, 10:56:56 am »
Pardon my ignorance, but what is a PAB? I mean, what does the acronym mean? I can read the schematic.
Offline tonewood
« Reply #3 on: June 18, 2012, 11:06:10 am »
Pre Amp Boost? remove the tone ckt?
Offline Geezer
« Reply #4 on: June 18, 2012, 11:10:13 am »
Correct, PAB = PreAmpBoost.....it's Dumble terminology, used on several of his amp designs, but especially the OverDrive Special (ODS)
G
« Reply #5 on: June 18, 2012, 04:13:00 pm »
I am not seeing the difference between the 5E3 and the redrawn 5E3 that is directly next to it.  (other than how they are drawn)
Can you indicate where they are different in functionality?
The psuedo/quasi- 5E3 shown inside the schematic is definitely different.  I have not gotten around to trying it yet, but plan to.
And the quasi-5E3 is the one I have been using on my builds and I like it.
« Last Edit: June 18, 2012, 04:23:24 pm by tubenit »
Offline tonewood
« Reply #6 on: June 18, 2012, 07:39:39 pm »
If you adjust the volume and tone pots to their half way points, there will be some resistance between the input and output in the drawing on the left. With the tone and volume adjusted the same way in the drawing on the right (redrawn version), there will be no resistance between the input and output.
In the drawing on the left, the center of the tone pot is directly connected to the output. Not so in the redrawn version. I think??
« Reply #7 on: June 18, 2012, 07:45:14 pm »
There's a dead short between input and output.
« Reply #8 on: June 18, 2012, 08:27:05 pm »
fixed.   :think1:
--DL
« Reply #9 on: June 18, 2012, 08:41:53 pm »
There just really isn't any elegant way to draw that circuit!  :grin:
« Reply #10 on: June 18, 2012, 08:55:25 pm »
Ah, yes!    What DL said!   Thanks
« Reply #11 on: June 18, 2012, 09:35:17 pm »
true dat! we (i do anyway) make an effort to avoid crossed lines when drawing a schematic. the original fender schematic does not indicate pot orientation and that can be confusing to novices.
--DL
« Reply #12 on: June 19, 2012, 09:29:38 am »
So true! It gets me every time (I'm not very accomplished at this) and I always have to look at their layout. But having said that, to me, those Fender schematics and layouts are really the Holy Grail of written guitar amp circuitry; they are so beautifully drawn and clear to read in a functional sense that I just love them. When I look at those, I have the illusion of understanding, LOL.
