September 13, 2026, 09:30:22 pm
Hoffman Amps Forum image Author Topic: Alternatives to Fender strain relief ?  (Read 12052 times)
Offline worth
« on: June 15, 2012, 07:57:30 am »
I'm really tired of wrestling with the Fender power cord strain relief.. what other options are out there besides the IEC ? I've looked at Mouser , but didn't see anything.
Re: Alternatives to Fender strain relief ?
« Reply #1 on: June 15, 2012, 08:03:31 am »
There is a tool for this.  Makes it easy.  Here is one.
http://www.amazon.com/Heyco-STANDARD-STRAIN-RELIEF-PLIERS/dp/B001BPY6KI
Offline worth
« Reply #2 on: June 15, 2012, 08:06:46 am »
Thanks... I have the tool , but it's still a pain.
Offline Tyrannocaster
« Reply #3 on: June 15, 2012, 08:38:41 am »
I have used Doug's method of putting a grommet inn the chassis instead of the strain relief and then screwing the cord to the cab via one of those plastic side clamps (no idea what they are called). It works pretty well, but you must use the plastic clamp as the grommet alone won't keep the cord from going in and out even with cable ties on each side of the chassis (Doug's recommendation).
Those pliers look cool but they are way out of  my budget!
« Reply #4 on: June 15, 2012, 09:04:25 am »
Grommet in a hole & plastic ties on either side of the grommet.
Offline birt
« Reply #5 on: June 15, 2012, 09:15:39 am »
a grommet and if possible i use a cable tie to fix it to something else in the chassis. like a PT bolt or something.
Offline worth
« Reply #6 on: June 15, 2012, 09:20:20 am »
I used to do the grommet with plastic ties , but the cord wasn't held tightly enough, and rotated in the grommet too much. I like the one in the pictures ... plastic, with a right angle through the chassis hole, ( from an old Yamaha bass amp).
« Reply #7 on: June 15, 2012, 09:28:00 am »
There are a few flex cord box connector options in the electrical section of Lowes. None is as elegant as the simple Heyco style strain relief. This is the best looking of the lot in the electrical section...
http://www.lowes.com/ProductDisplay?partNumber=108659-15527-49212&langId=-1&storeId=10151&productId=3150213&catalogId=10051&cmRelshp=req&rel=nofollow&cId=PDIO1
Offline steven
« Reply #8 on: June 15, 2012, 09:46:52 am »
Might be overkill, but I switched to Neutrik Powercons. I only have to drill a big, round hole, something I can handle. Disadvantage: if someone, say a drunk drummer, trips over the cord, the whole thing comes crashing down. Advantage: nobody ever steals the cord, because 1) they can't figure out how to get it out; and 2) nobody else can use it.
steven
« Reply #9 on: June 15, 2012, 09:58:28 am »
respectfully, grommet and wire ties are totally unsafe and a fire/shock hazard. the cord should NOT be allowed to rotate. unless you can cut a semicircle, then a strain relief in a drilled hole is nearly as dangerous.
there are alternatives - some uglier than others.
http://www.breakerking.com/catalog/index.php?main_page=index&cPath=8_87
i'd use the relief with the chinese finger in that lineup.
IEC is the safest. conventional fender type strain reliefs are generally not accepted practice anymore and manufacturers have been moving away from the practice; they are still supplied mainly for replacement. IEC makes world-wide marketing easier as well, just supply the correct power cord for the region/country.
bite the bullet - grab your dremel tool and cut the IEC hole.
respectfully,
--DL
« Reply #10 on: June 15, 2012, 10:16:21 am »
I appreciate what you are saying. However, if the cord is screwed to the side of the cabinet as well with a plastic whatever-it-is I don't see how the cord can rotate. As for cutting IEC holes with a Dremel...well, you are obviously much more skilled than I am with a Dremel.
Offline worth
« Reply #11 on: June 15, 2012, 11:12:33 am »
Found this.... they provide free samples.
Offline tonewood
« Reply #12 on: June 15, 2012, 01:21:51 pm »
Who are they?
-thanks
Offline gldtp99
« Reply #13 on: June 15, 2012, 03:03:57 pm »
Offline worth
« Reply #14 on: June 15, 2012, 03:41:13 pm »
Who are they?
-thanks
uniteduniversal.com
« Last Edit: June 15, 2012, 03:43:30 pm by worth »
Offline phsyconoodler
« Reply #15 on: June 15, 2012, 04:29:23 pm »
Heat the cable with a heat gun before installing the strain relef.It will slide right in.Not too much heat,just enough to make it softer.
  Works every time for me.No struggling at all.
Offline Fresh_Start
  • noob de Lux
« Reply #16 on: June 15, 2012, 10:07:06 pm »
I really like the IEC socket with the integral fuse holder that Doug sells.  Cutting the hole takes a little while with a steel chassis, but it's tidy and safe.
Physco - Thanks for the tip about heating the cord a bit for a traditional install.  BTW I always add a clamp to the cab in that case.
Cheers,
Chip
Quote from: jjasilli
Quote from: PRR
Offline LooseChange
    • Fix Your Darn Amps
« Reply #17 on: June 16, 2012, 06:36:55 am »
Great tip... Now why didn't I think of that.
I have installed MANY IEC connectors. A hard wired power cord has no place on a head!
Call me Dan
www.fydamps.com
Offline bartman
« Reply #18 on: July 01, 2012, 09:18:57 am »
Hey All...
Who sells an IEC punch to fit Doug's connectors? I checked Greenlee's site, n/a.
Thanks, bart
« Reply #19 on: July 01, 2012, 09:31:16 am »
What tubenit said is how I usually do that:
Offline Katie 77
« Reply #20 on: July 01, 2012, 09:45:29 am »
« Reply #21 on: July 02, 2012, 12:53:29 am »
The ones I've seen in catalogs are at least $250.00 +, or were they $350.00+.    :w2:
                           Brad      :think1:
« Reply #22 on: July 02, 2012, 06:25:52 am »
I was looking around for one a while back, and yeah they are plenty expensive. If you were building an amp per week it'd be well worth it. But for a guy like me drilling the corners and a jigsaw works fine.
