July 29, 2026, 04:36:05 am
Hoffman Amps Forum image Author Topic: Bright cap vs lugs  (Read 7976 times)
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
Bright cap vs lugs
« on: June 21, 2012, 09:19:27 am »
I've seen some place the bright cap across the outer lugs of the volume pot, while others use the outer/inner lugs.  Why the discrepancy?
FDeSalvo,
Principal Engineer & Owner,
Offline thelonious
  • t00b n00b
Re: Bright cap vs lugs
« Reply #1 on: June 21, 2012, 09:44:01 am »
Do you mean that on some the cap is placed from lug 1 to lug 3 (outer lug to outer lug) instead of from lug 1 to lug 2 (outer to inner)? Because it seems like lug 1 to lug 3 would short high frequencies to ground and act as a LPF instead of a bright cap---if lug 3 is in fact connected to ground, and I am correctly interpreting what you mean.
Offline fdesalvo
  • "...I can walk!!"
« Reply #2 on: June 21, 2012, 09:50:42 am »
Yep that's what I mean. Just curious. I might move mine around and see if there's a difference.
FDeSalvo,
« Reply #3 on: June 21, 2012, 10:05:30 am »
If you put it on the outer lugs it will become a dull cap. :wink:
The bright cap only works when connected across the ungrounded lugs of the volume pot. You may want to use a switch like this...
Offline fdesalvo
  • "...I can walk!!"
« Reply #4 on: June 21, 2012, 10:13:10 am »
Interesting indeed!  I've only got a 500pf and a 250pf cap laying about.  I know the trad bf value is ~120pf.  Wondering if the 250pf will be too bright!  Only one way to find out.
FDeSalvo,
Offline birt
« Reply #5 on: June 21, 2012, 10:24:13 am »
wire both caps in series and you end up with about 167pF
Offline fdesalvo
  • "...I can walk!!"
« Reply #6 on: June 21, 2012, 10:46:50 am »
Thank you.  I was also thinking about possible setting up a switch to choose between a couple caps - might come in handy since we play so many venues that have various cabs in the backline.  I just whipped this up - does this look right?
FDeSalvo,
« Reply #7 on: June 21, 2012, 11:18:02 am »
That's a good idea.
Offline thelonious
  • t00b n00b
« Reply #8 on: June 21, 2012, 01:01:49 pm »
Cool. I like the switched cap options idea. Or if you settle on one cap value that you like a lot, I think you could get switchable levels of boost by wiring a resistor in series as below. Does that look right?
Offline fdesalvo
  • "...I can walk!!"
« Reply #9 on: June 21, 2012, 01:12:45 pm »
I like where this is going. Just finished messing with some brigh cap options.
500pf or 250pf = pure pain
250pf + 250pf in series = just right. Able to turn down treble pot, giving more range to other tone controls.  In other words...about 125pf lol I guess fender knew what they were doing??
I ordered a CTS 1MA push-pul pot since I already had my faceplate made up.  Kinda sad to remove that sweet PEC!
« Last Edit: June 21, 2012, 03:51:22 pm by fdesalvo »
FDeSalvo,
Offline The_Gaz
« Reply #10 on: June 22, 2012, 01:44:18 pm »
Another cool trick, especially with the push-pull pots is to replace the green wire in your  drawing with a resistor (try 47K-1M). This puts a resistor in series with bright cap, which boosts the same frequenter, but limits the 'height' or amount of boost.
And in regards to your first post wiring a cap on the outer lugs (just because it's on the lugs does not make it a bright cap) is just a convenient place to wire a cap to ground to cut highs, ad the rotation of the pot will have no effect on the cap. On the other hand (or other lugs I should say) - the wiper and ground lugs - the sound will get darker as you turn up the volume, this can be very useful in certain amps that get brittle or fizzy when cranked up too much. Of course you can always use a bright and dark cap i conjunction!
Offline fdesalvo
  • "...I can walk!!"
« Reply #11 on: June 22, 2012, 03:27:26 pm »
Thanks for your insight!
I imagine once could use this idea to create a mid shift type arrangement on the mid pot, too.
FDeSalvo,
« Reply #12 on: July 02, 2012, 08:51:21 pm »
Here is a little deal I use.
Offline fdesalvo
  • "...I can walk!!"
« Reply #13 on: July 02, 2012, 09:00:03 pm »
Way cool, Ed. :)
I ended up tossin the bright cap idea altogether.  I went down in value until I hit 50pf and still found it too trebly.   Sort of wish I had a presence pot, but honestly the amp sounds just fine without it.
FDeSalvo,
