September 13, 2026, 01:26:38 am
Hoffman Amps Forum image Author Topic: Location/order of artificial heater center tap?  (Read 5495 times)
Offline thelonious
  • t00b n00b
« on: July 05, 2012, 10:28:44 am »
Working on converting an old 2x6V6 PA amp, and it has a bit of heater hum. It has no hum-balance pot or heater center tap. The heaters are wired in parallel.
When I add an artificial center tap, does it matter where the 100R resistors get wired into the heater chain? For instance, could I kill two birds with one stone by soldering the 100R resistors onto a power tube socket from cathode to each heater pin on the same socket, or is this a Very Bad Idea? :icon_biggrin:
Thanks!
Re: Location/order of artificial heater center tap?
« Reply #1 on: July 05, 2012, 10:37:43 am »
Sounds good to me.
Offline thelonious
  • t00b n00b
« Reply #2 on: July 05, 2012, 10:39:10 am »
Thanks, Sluckey!
« Reply #3 on: July 06, 2012, 05:43:24 pm »
For others' reference:
I know you normally see those resistors on, say, the pilot light of a blackface amp.
I built a 5E3 once and forget to include them during the build. Once the amp was done and fired up, the only easily-available room was at the first preamp tube. I crimped one end of both 100Ω resistors in a ring terminal. I bolted that down with the screw/nut holding one side of the first preamp tube socket. Then I soldered the other end to each end of the filament string at that tube (pins 4/5 and 9).
Worked perfectly. No need to keep those resistors at the PT end of the chassis.
« Reply #4 on: July 06, 2012, 07:02:37 pm »
I had always wondered about that. Thanks!
Offline Davidg
« Reply #5 on: July 08, 2012, 03:33:38 am »
yea that shouldnt be a problem-I have an old taynor that has it located between the PI and power tubes.Worried me a bit at first cause it was the first one I had seen like that and the schem had it by the pilot light.Had atube short and those resistors burnt up just like they should -actually twice before I found the short :icon_biggrin:
Offline thelonious
  • t00b n00b
« Reply #6 on: July 08, 2012, 07:26:57 pm »
Thanks, guys! Worked like a charm. :occasion14:
Offline LooseChange
    • Fix Your Darn Amps
« Reply #7 on: July 09, 2012, 05:35:36 am »
I like it.
Call me Dan
www.fydamps.com
