September 12, 2026, 10:25:42 pm
Hoffman Amps Forum image Author Topic: Multitap output transformer for 5E3  (Read 4472 times)
Offline olgoat
« on: July 05, 2012, 03:27:42 pm »
I ordered up a Mag Component Classic Tone multitap output transformer for a 5E3 build that I completed.  Anyone have any clever ideas on how to wire up a selector switch to select 4/8/ or 16 ohm output?   A 3 position rotary switch?   A round hole would be easier to make in the chassis that a rectangle for a slide switch.
Any thoughts would be much appreciated. You guys probably do this all the time.
I am putting the chassis into a 2-10 cabinet and the speaker selection is more limited than I would like given the current 8 ohm output of the chassis.
Tim
Re: Multitap output transformer for 5E3
« Reply #1 on: July 05, 2012, 05:10:52 pm »
3 Way rotary impedance switch, sold by Hoffman.
"Fits into existing 1/4 jack holes (3/8" hole).
Body depth = 21mm. Body outside diameter = 34.5mm not including solder tabs.
You can bend the solder tabs over if you need more chassis clearance."
$10.25
Measure your chassis 3 times to make sure it will fit, with room to spare.
Offline olgoat
« Reply #2 on: July 05, 2012, 05:24:01 pm »
Cool.  Thanks. Sounds like the perfect solution.  Leave it to Doug.
« Reply #3 on: July 05, 2012, 05:58:55 pm »
- if you have a custom chassis and you DRILLed a 3/8" hole with a 3/8" BIT for your jacks, it will NOT fit. with most amps and chassis supplied the jack/pot holes are larger than 3/8", typically .406" +/-. use a 13/32" bit to make a hole for this switch; the bushing is M10 with .75mm thread pitch.
respectfully, just to clarify...
--DL
