September 12, 2026, 10:26:45 pm
Hoffman Amps Forum image Author Topic: Broken Guide Pins  (Read 5937 times)
Broken Guide Pins
« on: July 06, 2012, 05:54:21 pm »
I have seen a thin plate that slides over the tube pins to replace a broken guide pins.  I cannot seem to locate them.  i found the thick ones on Ebay, but none of the thin.  You can actually put a little glue on them and repair the tube.   Anybody know who sells these things?
Offline fdesalvo
  • "...I can walk!!"
    • Forgotten Gear Restorations
Re: Broken Guide Pins
« Reply #1 on: July 06, 2012, 06:02:13 pm »
FDeSalvo,
Principal Engineer & Owner,
« Reply #2 on: July 06, 2012, 09:25:06 pm »
« Reply #3 on: July 06, 2012, 09:29:50 pm »
And don't glue them, so that you can reuse it with other tubes.
The holes are small enough to provide a fairly snug fit with the tube.
Offline billcreller
  • 1934
« Reply #4 on: July 07, 2012, 02:07:23 am »
 Since I have a lot of old tubes, I keep some of those around.  They do hold the tube out of the socket a bit, but seem to do the job.
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« Reply #5 on: July 07, 2012, 06:02:33 am »
Yep...
http://www.tubesandmore.com/products/P-STKY-1
10 bucks for 4 is cheap enough , I just ordered some myself , every shop should have these  :guitar1
Offline LooseChange
    • Fix Your Darn Amps
« Reply #6 on: July 07, 2012, 06:46:02 am »
I have a few of those little devices but the most important thing to do is mark the tube base as to where the key should be. I use a silver Sharpie.
Call me Dan
www.fydamps.com
« Reply #7 on: July 07, 2012, 08:28:11 am »
Thanks, on the way.
