September 12, 2026, 08:23:02 pm
Hoffman Amps Forum image Author Topic: Which are the cheap & more expensive way to know if there is self-oscillation ?  (Read 4613 times)
Assuming there is a self-oscillation on a circuit which are the more cheap and the more expensive solution to discover it ?
I'm thinking to something that can't be hear like when the self-oscillation isn't at audio frequency
how is possible to discover it for sure in the cheaper way ?
exist an expensive way to discover it, a devoted instrument, something like a frequency scanner ?
Cheap: thinking about why the amp is not working
Expensive: oscilloscope
EDIT: Mid-price: A.M. radio tuned between stations. An oscillation in the kHz range will likely show up as a noise other than the normal static on an a.m. radio.
« Last Edit: July 06, 2012, 11:16:42 pm by HotBluePlates »
Hi HBP
Very simple and ingenious !
at the moment, here in Italy, are about to be closed even the latest medium wave stations
that is something to give a taste  :icon_biggrin:
« Last Edit: July 07, 2012, 01:44:26 am by kagliostro »
