September 13, 2026, 12:30:46 am
Hoffman Amps Forum image Author Topic: Ampeg J-20 Bias  (Read 5992 times)
Offline Leevi
    • Rikstone
Ampeg J-20 Bias
« on: July 07, 2012, 04:56:46 am »
I installed a VVR from Skipzcircuit to Ampeg J-20 and made a mistake.
I forgot to measure the value of the fixed bias voltage before installation. Does anyone know how much
it should be? I'm currently using -40V with full B+. When using lowest B+ the voltage decreases to -65V.
Does this sound correct?
Vari-Watt:
http://www.skipzcircuits.com/VariWattFX.html
Ampeg J-20:
http://www.prowessamplifiers.com/schematics/images/J20_Schem_w_transformer2.pdf
/Leevi
Re: Ampeg J-20 Bias
« Reply #1 on: July 07, 2012, 08:52:46 am »
No, not correct.
The kit you linked claims tracking bias, which would hopefully make it a licensed version of London Power's Powerscale circuit. The bias board should track the reduction in B+ so that as the B+ is reduced, the bias gets smaller (not larger). So your bias might reduce to something like -25v a minimum B+.
Check the interconnections to the bias board, and check for proper orientation of your transistors and MOSFETs.
Offline Leevi
    • Rikstone
Re: Ampeg J-20 Bias
« Reply #2 on: July 07, 2012, 12:48:52 pm »
The kit seems to work correctly. It was my fault again because I measured the bias voltage
from wrong point. When measuring on the grid the voltage goes close to zero on the lowest B+ which is almost zero then.
There is a trimmer pot on the bias adjusting board where you can set the base value for the bias.
In my case with full B+ the maximum value I can set is about -42V. Hopefully this is OK for Ampeg J-20?
/Leevi
« Last Edit: July 07, 2012, 04:48:34 pm by Leevi »
Re: Ampeg J-20 Bias
« Reply #3 on: July 07, 2012, 04:08:18 pm »
Sounds reasonable. You could measure the tube plate current to find out for sure.
I don't normally endorse the transformer shunt method, but if you clips the meter leads in place before powering the circuit, you can do it without upsetting the circuit or your nerves.
