September 08, 2026, 02:47:10 pm
Hoffman Amps Forum image Author Topic: LED timer  (Read 7659 times)
Offline rzenc
  • TUBES RULE
LED timer
« on: July 10, 2012, 09:42:26 am »
Hi there,
So, I was asked to built a kind of toy...a push button which turn on a led for about 10s and then it should come off....well, I did in on the protoboard and it worked...build a prototype and it worked...
I gave it to a friend...it's working fine...
Another friend saw it and wanted one too...instead of making another PCB, I decided to build it on the protoboard again in order to check current flow on components and to my surprise..it doesn't want to work anymore... :help:
It turns on but never comes off....
Schem is attached...I used guidelines from LM555C to make a monostable circuit...the actual chip is NE555N
I have fooled around with different combinations of R & C but no joy yet...either it works for about 1.5s and shuts off or it just never turns off...it's driving me mad...
Links to both datasheet of 555 chips
http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000479.pdf
http://www.ti.com/lit/ds/symlink/lm555.pdf
Can you guys help me out?? don't know where to look since I have limited experience with SS and chips...
Thanks in advance for all
Best Regards
R.
« Last Edit: July 10, 2012, 09:49:45 am by rzenc »
Re: LED timer
« Reply #1 on: July 10, 2012, 11:08:44 am »
Where's your timing cap???
Wire it like this...
Offline rzenc
  • TUBES RULE
Re: LED timer
« Reply #2 on: July 10, 2012, 12:41:43 pm »
I may have deleted it accidentaly...
I will try your suggestions
THANKS Steve :worthy1:
Best Regards
R.
Offline rzenc
  • TUBES RULE
Re: LED timer
« Reply #3 on: July 10, 2012, 02:19:16 pm »
Thanks a lot Steve!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
It's not only working, but also got a plus since the other circuit was lighting the LED's when first turning it on....and now it doesn't until I hit the button!!!
GOD SAVE STEVE!!!!!!!!!!!!!!
Best Regards
R.
