August 05, 2026, 05:08:43 pm
Hoffman Amps Forum image Author Topic: Peavey 6505+ - Question about heaters and V3b cathode (pin8)  (Read 5912 times)
Offline six el six
I have both ac and dc voltages on my heaters all over this amp.
I am trying to understand how this heater supply circuit works.
1. Could someone explain to me what's going on here or point me to the part of Merlin's power supply book that would cover this type of heater circuit?
2. Also, what's up with the cathode on v3b?
I've got 147vdc there. Why?
Voltages and schematic attached.
six
Re: Peavey 6505+ - Question about heaters and V3b cathode (pin8)
« Reply #1 on: July 17, 2012, 02:55:08 pm »
It is a crazy looking filament scheme. Some tubes are heated with DC and others are heated with AC. Even the AC is referenced to +24vdc. Peavey probably used dc filaments in sensitive or high gain circuits to reduce noise.
V3B is a cathode follower. That high voltage on the cathode is typical. There's also a high voltage on the grid.
Offline six el six
« Reply #2 on: July 17, 2012, 03:10:52 pm »
I understand that V3b is a cathode follower.
What I don't understand is where the 147vdc is coming from??  :w2:
Is the schematic incomplete?
« Reply #3 on: July 17, 2012, 03:42:00 pm »
The tube plate is connected directly to a B+ source. The tube can be thought of as a variable resistor between plate and cathode. The grid controls the amount of resistance (or conductance) and allows more or less current to pass thru the tube. That current passes thru the cathode resistor then from cathode to plate inside the tube. The current causes a voltage drop across the cathode resistor. For example, 1ma of current thru a 100K resistor will cause a voltage drop of 100V across that resistor.
