August 05, 2026, 02:03:38 am
Hoffman Amps Forum image Author Topic: Need recommendation on "clean 25-50 watt" amp build for pedals  (Read 5118 times)
Offline m3moser
Hey Folks- I have a request for a 25 to 50 watt clean amp to be used as a basis for high gain metal style pedals to be plugged into the front end.  You know, those pedals like the Mesa Twin V or those Damage control or other "preamp" style pedals.  The customer wants to keep it in his studio along with a collection of these pedals for his high gain clients.  Its really just a pretty plain mostly power amp build, I am just looking for recommendation on which circuit might fill the bill.
  Any ideas?
Re: Need recommendation on "clean 25-50 watt" amp build for pedals
« Reply #1 on: July 19, 2012, 04:54:22 pm »
AB 763
« Reply #2 on: July 20, 2012, 12:25:12 am »
Hi m3, found this in my schems, i don't know much about it but its called CLEAN TONE?
Offline stingray_65
« Reply #3 on: July 20, 2012, 01:01:23 am »
AB 763
What he said! +1
Classically clean and pedal friendly
Offline skyclad
« Reply #4 on: July 20, 2012, 06:02:55 pm »
I love my AB763 Deluxe Reverb, but for clean tones I'd go 40 watts or better.
sky
Offline gldtp99
« Reply #5 on: July 21, 2012, 08:33:15 am »
I'd go with the normal channel here: http://www.el34world.com/charts/Schematics/files/fender/bandmaster_ab763_schem.pdf
Tighten up the 1st stage filtering value to @100uF (stock is 35uF). Can also try increasing the Screen filtering, but not as drastically as the 1st stage. You want tight, yes ? To sound best with high gain pedals, but not necessarily the best set-up for use without these types of pedals/preamps ?
Use this OT: http://www.classictone.net/40-18001.html
I'd also use the stock Fender input jack configuration---- the padded input (jack 2) could be useful if the customer uses a seperate high gain preamp or a high gain pedal with an unusually hot signal--- It would give an extra measure of versatility--- you never know what someone is going to bring to a studio to record with.
Install a 10K pot in place of the 6.8k resistor from bass pot to ground to add Mid control (or see this AB763 Showman schematic): http://www.el34world.com/charts/Schematics/files/fender/SHOWMAN_AB763.pdf
If you want a head that would have deeper/more detailed sound then build the 85 watt Showman version--- with similarly increased 1st stage filtering---- The extra power is probably not needed in the studio and would require speakers that would handle the power level.
I'd go with the Bandmaster AB763 version(with stiffer filtering)-- One of my BF Bandmasters is similar to this idea (has Heyboer BF Bassman-type 4/8/16 OT---amp was set up before Classic Tone came out with their great sounding and cheaper OT)---- this one has stock Fender filtering values and has been used on several recordings, as a pedal base,  but gets a little too loose when used with true modern high gain preamps and low guitar tuning-------One modern metal band brought over their guitar and rack preamps and were looking for a tube poweramp----- a Hiwatt DR103 clone i did worked better than the Bandmaster for them--- but they were playing at very high vol levels and driving the Bandmaster into clipping----after finding out how much Hiwatts (and Hiwatt clones) cost, they decided to stay with their solid state poweramps--- Hiwatt circuits aren't simple or cheap to build------ Bandmasters work well as pedal platforms within the practical limits of their volume output potential.
Advantages:
Simple to build
Parts easily available and reasonably priced
Sounds terrific
Disadvantages:
None
« Last Edit: July 21, 2012, 08:52:59 am by gldtp99 »
Offline m3moser
« Reply #6 on: July 21, 2012, 01:55:52 pm »
Thanks Guys- let me look these over then discuss with the customer.  I see a few things here to chew over and recommend to him.  I appreciate the recommendations on this!!
