August 05, 2026, 01:14:10 am
Hoffman Amps Forum image Author Topic: Wire gauge question  (Read 4573 times)
Offline bartman
Wire gauge question
« on: July 20, 2012, 04:20:08 pm »
In June I bought a MOD KIT 102 amp kit ( 1x12ax7, 1xEL84, SS rectifier). (I know, sorry now). Any way, every thing I'm seeing now uses 20ga wire for AC/DC signal/supply voltage but 18ga wire for the heaters. My kit supplies 20ga for all. 1amp slo-blow mains. Most Fenders use either a 2 or 3amp fuse. Is 18 gauge necessary for the heaters?
Thank you,
Bart
Re: Wire gauge question
« Reply #1 on: July 20, 2012, 04:41:33 pm »
Not for that amp.
Offline bartman
« Reply #2 on: July 20, 2012, 05:22:06 pm »
Thank you Steve,
Is htr wire gauge based on pwr tubes (first in feeding chain)?
I have a '67 BF Bassman (AB165) I'd like to backdate. Should I use 18ga htr wire?
Bart
« Reply #3 on: July 20, 2012, 08:43:16 pm »
I think quite a few people use 18 gauge on the power tubes and 20 on the preamp tubes. Come to think of it, that's what I did too.  :icon_biggrin: HTH.
Offline archaos
« Reply #4 on: July 24, 2012, 07:13:56 am »
Bart
The wire gauge is based on the current drawn by the tubes. In an AB165 there are :
2 x 6L6GCs requiring 0.9A each in the power section
3 x 7025 & 1 x 12AT7 requiring 0.3 each in the preamp section
Furthermore, we know that the load carrying capacities of 18GA wire & 20GA wire are respectively of 2.3A & 1.5A.
Therefore you need 18GA for the power tubes & 20GA for the preamp tubes to be safe.
Yet, you can a fortiori use 18GA everywhere to be safe as well.
« Last Edit: July 24, 2012, 07:16:12 am by archaos »
I have stopped being surprised at the guitar player who spends $3,000 on the latest boutique amplifier, and plugs in his Mexican Stratocaster strung with light gauge strings through a Big Muff Pi fuzz pedal.
Mehr Licht !
