September 17, 2026, 02:10:30 pm
Hoffman Amps Forum image Author Topic: minature alpha pots  (Read 4066 times)
minature alpha pots
« on: August 02, 2012, 09:46:12 am »
I am contemplating trying to an active FX loop to an amp?
I am wondering if the 1/4 watt minature alpha pots would work where I have indicated?   Coming off the send cathode, I wasn't sure if that would be a problem.  I have used them on other builds and (so far) without a problem.
I also thought about using 1/4 watt minature pots that are 500k and then using a 1/2 or 1 watt 470k resistor across the outer lugs.  I don't know if that would "strengthen it" or whether the "weaker" 1/4 pot would still be just as weak?
The issue is VERY little chassis space to work with.
Thoughts?     With respect, Tubenit
Re: minature alpha pots
« Reply #1 on: August 02, 2012, 10:10:13 am »
I think you'll be fine. There's nothing on your schematic that would cause a problem. Hopefully there's nothing in your pedals that would harm the pots. (That's very unlikely.)
