September 16, 2026, 07:43:59 pm
Hoffman Amps Forum image Author Topic: EMI Comparison: Cannabis Rex, Red White & Blues, the Wizard  (Read 7574 times)
Offline seedlings
« on: August 06, 2012, 09:04:28 am »
I recorded a 3-chord sample of each of these speakers the other day so I could compare them quickly rather than plug-unplug cords, because I found that I liked whichever one was hooked up at the time.  Note that the Wizard is in a small, sealed enclosure, the Cannabis Rex in a large pine open-back, and the RW&B in a medium-sized birch ply open-back.  To me the Wizard sounds much better sealed than open.
Played through a ~45W 6L6GC PP amp at full power to get some speaker compression (except the 120W RW&B), the Wizard was 124dB, CR 122dB, RW&B 120dB.
Cannabis Rex, Red White & Blues, The Wizard Speaker Comparison
CHAD
Re: EMI Comparison: Cannabis Rex, Red White & Blues, the Wizard
« Reply #1 on: August 08, 2012, 05:25:27 am »
Hey, thanks for the sound clips comparison!   I use the Red, White & Blues for my Tweed BluezMeister.  I've used the Cannabis Rex for the Tweed Overdrive Special  & this recent D'Mars OD Special 5879.
I like both of those speakers.
with respect, Tubenit
Offline darkbluemurder
« Reply #2 on: August 09, 2012, 05:11:23 am »
Out of these speakers I only have experience with the Wizard, which I found very loud and very bright. Too much so in my Club Deluxe but it worked well in my modded Fender Deluxe II Reverb.
Cheers Stephan
Offline seedlings
« Reply #3 on: August 10, 2012, 01:09:29 pm »
Cheers Stephan
The Wiz is exactly that: loud and bright.  Have you tried it in a small (as small as .8 cubic ft !) sealed enclosure?  It sounds better than open-back to me.  It's also improved with enough wattage through it to wake the dead - once it starts to compress a bit itself.
CHAD
