September 08, 2026, 03:48:27 pm
Hoffman Amps Forum image Author Topic: Power transformer interference      (Read 5386 times)
Offline Geezer
« on: June 17, 2005, 09:28:07 pm »
        > Power transformer interference
<< Prev Topic | Next Topic >>
Author  Comment
cplais2
Junior tube assistant
(2/21/04 10:53 pm)
 Is there a possibility for the power transformer to interfere with the output transformer or the circuit board if they are too close to it? Does the grounded aluminum chassis have anything to do with preventing this? Also, is a grounded cap can necessary to shield the circuitry from any interference produced by the capacitors.
6G6
(2/23/04 5:04 pm)
 Re: Power transformer interference
 Yes.
The OT & the PT should be turned 90 degrees from each other and not be too close.
Anytime you have current going through a wire wrapped around a nail, bolt or in this case iron laminations, there is a magnetic feild. If the feilds overlap the signal will try to transfer from one to the other.
You want to prevent the 50 or 60 Hz AC in the PT from getting into the OT due to inductance.
cplais2
(2/24/04 12:45 pm)
 Interference
 Thanks 6G6.
Can the transformers or the filter caps interfere with the circuit board or the tubes?
Rotting27
(2/24/04 3:55 pm)
 Re: Interference
 Any time there is current of any sort AC or DC there is the possibility of "interference". If you follow the reasonable conventions of twisting wires, shielding wires, separating and orienting transformers, chokes, etc, and as little jumbling of wires in general, you should be fine.
If you need specifics on which wires to twist, shield, isolate, etc, how to orient transformers, layout a board, etc, let us know. I'm sure you can find a lot on the rest of the posts and archives, but you may still have a few specific questions.
Hope that helps
 Topic Commands
Powered By ezboard® Ver. 7.32
