September 17, 2026, 07:35:17 am
Hoffman Amps Forum image Author Topic: Capacitor Substitution Sanity Check  (Read 6043 times)
Offline cgiesel1
« on: August 25, 2012, 09:17:19 am »
Morning all,
I am getting ready to replace the electrolytic capacitors in my old tube amp.
I know it is ok to substitute for the nearest values --uf/v-- but is there a rule of thumb regarding how different the values can be?  What is too different?
The substitutions in question are:
Power supply filter capacitor:
Original equipment:
Multisection
Sprague 270021-56                Substitution with capacitor pack
40uf 450v                             JJ  47uf  500v
30uf 450v                            F&T 30uf 500v
10uf 450v                            F&T 16uf 475v
20uf 25v                         Sprague Atom Aluminum 25uf 25v
The biggest issue I have is the speaker crossover. Can I sub the 16uf 25v caps for 25uf 25v or would that go badly?  I am thinking a close match is a bit more critical in this case? Would I need to change out the resistors?
Speaker crossover:
Original                    Substitute with this?
16uf 25v                  25uf 25v?
the crossover circuit looks like this:  (r2 and r3 go to one terminal, transformer goes to a separate terminal)
                                                               [ R2 33ohm@20%                              |--> OUT
IN? -->[R1 10ohm@20%]-->[cap 16uf/25v]-->| R3 2.2 P 3v                                    |        [ Transformer pri 6000ohm sec 4-6 ohm ]--> OUT
Any advice would be appreciated
« Last Edit: August 25, 2012, 12:40:09 pm by cgiesel1 »
Re: Capacitor Substitution Sanity Check
« Reply #1 on: August 25, 2012, 10:35:59 am »
All that should be fine. You might notice a difference with the crossover cap though, I'm not sure. Somebody will be along shortly that knows for sure. :smiley:
« Reply #2 on: August 25, 2012, 10:21:38 pm »
The power DC filter caps are polarized, fine.
Speaker crossover caps *must* be bipolar/nonpolar (or not electrolytic, but in these values a fine film cap would be huge and costly(*)).
Look to DIY speaker stores for crossover caps.
25V on a LOUDspeaker crossover cap is pretty cheezy. OK for a 90-day warranty, but if you like the amp more than 90 months you oughta replace with >50V caps.
Try to stay within ~~20% of nominal crossover cap value. For "16u", aim at 13uFd-19uFd. In today's value-series, 15u is the new 16u.
PartsExpress has been around for decades:
http://www.parts-express.com/
http://www.parts-express.com/cat/non-polarized-electrolytic-capacitors/293
(*) Actually, PE's price for 15u of fancy-film cap is not horrible, and it will last forever.
Metalized Polypropylene Capacitors
« Last Edit: August 25, 2012, 10:34:47 pm by PRR »
Offline cgiesel1
« Reply #3 on: August 25, 2012, 10:59:58 pm »
Thanks for the reply.  Parts express is one of my favorite sites.  Good call on the non-polarized crossover cap.  A closer examination of the cap showed that it is indeed non polarized.
« Last Edit: August 25, 2012, 11:02:38 pm by cgiesel1 »
