September 16, 2026, 11:18:29 pm
Hoffman Amps Forum image Author Topic: SE AMP build idea ?  (Read 8289 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
SE AMP build idea ?
« on: October 07, 2012, 11:55:30 am »
Hi, my computer crashed with the major part of my schems :sad2: and I know I had a couple of SE schems in there.
I want to build a dual EL34 SE amp and I can't seem to find what i want to on the net.
Any idea, boys and gals ?
Regards, Colas.
P.S.: call me Alvin.
stratele52
  • Guest
Re: SE AMP build idea ?
« Reply #1 on: October 07, 2012, 01:15:14 pm »
No hard disk copy Colas ?
Dual EL34 SE , you mean strereo amp ?
  • MAKE LOVE NOT WAR
« Reply #2 on: October 07, 2012, 02:12:38 pm »
non, mono, pour guitare, entre 20 et 30W
merci
Colas
stratele52
  • Guest
« Reply #3 on: October 07, 2012, 02:35:25 pm »
merci
Colas
Mais que veux dire "dual EL34 SE "si ce n'est pas deux EL34 en single end ?
Tu voulais dire deux  EL34 pushpull alors ? Le SE signifie quoi ?
Autrement un schéma doit être facile a trouver sur le web non ?
« Reply #4 on: October 07, 2012, 02:56:35 pm »
No, non PP lui intende PPP PSE is the term I mean SORRY
p.s.: not sure, to me seems Tubeswell has draw a PPP PSE amp
« Last Edit: October 09, 2012, 08:11:34 am by kagliostro »
  • MAKE LOVE NOT WAR
« Reply #5 on: October 07, 2012, 03:10:03 pm »
DISREGARD.
stratele52
  • Guest
« Reply #6 on: October 07, 2012, 03:37:15 pm »
Offline spacelabstudio
  • Unable to leave well enough alone
« Reply #7 on: October 07, 2012, 06:34:55 pm »
Pensavo che questo forum fosse in inglese.  Communque, questo è un disegno intenzionalmente vago, per le massime possibilità:
http://ampnerds.spacelabstudio.com/projects/se1/index.html
  • MAKE LOVE NOT WAR
« Reply #8 on: October 07, 2012, 08:50:44 pm »
Scusi!
No francese o italiano, solamente inglese ?
Grazie per il ''link''
Stratele: parce que j'ai changé d'dée, voilà.
Colas
stratele52
  • Guest
« Reply #9 on: October 08, 2012, 03:46:23 am »
Colas LeGrippa
Excuse me, but I do not see you change your mind stop you from answering my questions.
It is also a matter of politeness.
  • MAKE LOVE NOT WAR
« Reply #10 on: October 08, 2012, 08:57:31 am »
Stratele, what are you talking about ? ''Disregard'' doesn't mean ''go fuck yourself '' , why do you think I am impolite ?
Colas
stratele52
  • Guest
« Reply #11 on: October 08, 2012, 02:50:32 pm »
Colas
 I asked you questions about your project (October 07)
You wrote later ; "disregard's it "
and then ;"I've changed my mind, that's it "
It seems to me that either know have been more appropriate to say more or answer my questions. As if you did not care that I'm  interested to your project.
This is what I found discourteous
  • MAKE LOVE NOT WAR
« Reply #12 on: October 08, 2012, 09:35:46 pm »
I apologize, Your majesty Louis the 14 th.
« Reply #13 on: October 09, 2012, 08:14:49 am »
I've just recognized that I was thinking PSE and I wrote PPP on my previous message
I mean Paralleled Sigle Ended amplifier
I apologize about the confusion I've generated
SORRY
« Reply #14 on: October 09, 2012, 09:26:11 am »
In general there's no great difference between paralleled single ended and regular single ended.  You can take any single ended design and make it a paralleled single ended design.  You'll be pulling twice as much current, which means:
- If you're using a shared cathode resistor, you'll need to halve it's value.
- You'll need to make sure your power and output transformers are rated for the higher current.
That's it, really.  Before I had it, someone turned my Vibrochamp into a parallel single ended amp.  I rewired it to use separate cathode resistors/bypass caps for each tube so that I could pull one or add it at will.  I never use both power tubes, though.  It's maybe a hair louder with both of them in there, but not much, and I somewhat prefer the sound of just the one power tube.
  • MAKE LOVE NOT WAR
« Reply #15 on: October 09, 2012, 10:56:43 am »
Kagliostro: you don't have to apologize for a typing error ! thanks anyway and have a good day, sei com' un fratello per me !
colas
Spacelab: thanks for the info, as I said in a post before I changed my mind since I wanted to use the PT and OT I had on my bench actually. So I have built a 2 X 6V6  SE amp that is AWESOME, though not as loud as a 2X EL34 could be.
I love you all !
stratele52
  • Guest
« Reply #16 on: October 12, 2012, 02:35:57 am »
Réponse démontrant un comportement immature.
Demonstrating a response of immature behavior
  • MAKE LOVE NOT WAR
« Reply #17 on: October 12, 2012, 08:55:13 am »
Can you say that in Italian too? If I were you, I'd concentrate my skills on amplifiers building. Why don't you write me a personnal message, if you have something to say on my behavior ? This forum is sure not the right way to go for that purpose. jacqueswprevost@gmail.com
