September 17, 2026, 09:22:33 am
Hoffman Amps Forum image Author Topic: el84 schedule 40 to 6v6 ?  (Read 5223 times)
Offline john_t
« on: October 08, 2012, 10:23:02 am »
I am considering changing my el 84 ga-5 build  to a 6v6 power tube. The el 84 has plenty of drive and crunch. After having the amp awhile Iam just not sure it's my taste. Can I just change out to the octal tube or would I need to swap out anything else.
john
Re: el84 schedule 40 to 6v6 ?
« Reply #1 on: October 08, 2012, 03:12:07 pm »
EL84=9 pin socket, 6V6=8 pin socket.
                Brad     :icon_biggrin:
Offline shortfuse
« Reply #2 on: October 08, 2012, 10:10:23 pm »
I built the ga5 / sch 40 in a alum chassis.  I never could get the b+ down to bias correctly and change mine out to a 6V6.  Was not that difficult.  If you want I can send you the diagrams I used.  Had a few suggestions to use a zenier to drop the voltage but I felt changing to the 6V6 would be better.  After the swap I thought is sounded better.  I also installed the moonlight push pull tone stack from the Adams amps site.
« Reply #3 on: October 08, 2012, 10:41:33 pm »
6V6 will need different bias than EL84.
Offline john_t
« Reply #4 on: October 09, 2012, 12:01:22 am »
Thanks for the help all. Shortfuse diagrams would be very helpful. Iam not sure how you get them to me. Or at least direct me to where I might find them.
Thanks John t
« Reply #5 on: October 09, 2012, 04:13:57 am »
Different socket with different pin out and different bias.
The 6V6 also likes its voltages a bit higher than an EL84. This may happen 'automatically' when you swap to a 6V6, as a 6V6 typically has lower tube current  than an EL84, so the load won't be as great.  Or this may be a matter of going to a more efficient rectifier tube (depending on what sort of windings your PT has). But if your power supply is already SS rectified, then you may just have to accept lower voltages for the 6V6 or change the PT.  If it were me I'd suck it and see with the existing PT first.
And you'll probably want a 470k grid load resistor for the 6V6
You should be able to get away with the same OT and speaker though.
« Last Edit: October 09, 2012, 11:15:44 am by tubeswell »
« Reply #6 on: October 09, 2012, 08:43:21 am »
Looking in the web I've found this
hope this can be of some help
« Last Edit: October 09, 2012, 08:50:10 am by kagliostro »
Offline shortfuse
« Reply #7 on: October 10, 2012, 12:43:35 am »
kagliostro got hem.  I used all 3 as references but did it like in the last one by Joe Piazza.
Offline john_t
« Reply #8 on: October 10, 2012, 08:35:14 am »
Shortfuse can you post the plans you used for your rebuild. Or I can shhot you My e address.
thanks John t
