September 17, 2026, 06:19:34 am
Hoffman Amps Forum image Author Topic: headphone line out on a tube amp  (Read 4725 times)
Offline gtrbryan
« on: October 08, 2012, 09:37:45 pm »
I would love to play through headphones with a tube amp.  What is the trick to doimg this.   I would guess there is a dummy load,  i have heard about a speaker simulators.  If any group has an idea it  will.be this one.  Get the best info here.  Thoughts.?  SCHEMATICS.
Re: headphone line out on a tube amp
« Reply #1 on: October 08, 2012, 10:42:58 pm »
Dummy load a MUST. And an attenuator so you are not sending whole WATTS to a milliwatt headphone.
Offline spacelabstudio
  • Unable to leave well enough alone
« Reply #2 on: October 09, 2012, 09:32:56 am »
I know it's not as fun as building, but I actually have one of these that I haven't used in a while and should probably sell:
https://taweber.powweb.com/weber/hpa50.htm
You could turn it into a science project, I guess, by reverse engineering it.  From what I remember there's a big wirewound rheostat and a pot in there.  I don't remember which is the headphone and which is the line out.
« Reply #3 on: October 09, 2012, 09:59:05 am »
May be this can help
Offline Dave
« Reply #4 on: October 10, 2012, 05:39:11 pm »
One way to avoid having to use a dummy load is to break the signal connection to the phase inverter and reroute to a headphone circuit upon plugging in the headphones.
That way, your power amp is still running, its just amplifying silence while your signal is routed to a head phone amp.
That is the way I have seen it done in Booger amps.
Dave
Offline alerich
  • This one goes to 11.
« Reply #5 on: October 10, 2012, 05:57:37 pm »
I don't know what wattage your amp is but this is the way Marshall did it in a little Studio 15 18 watt 2x6V6 amp I used to own. I never tried it with headphones but the level was way down. It sounded decent when plugging the speaker into it for late night practice. I really liked the idea of having a load on the OT in case you forgot to plug in a speaker.
