September 17, 2026, 08:17:07 am
Hoffman Amps Forum image Author Topic: Ot hole spacing  (Read 4141 times)
Offline Stankfut
Ot hole spacing
« on: October 09, 2012, 11:33:18 am »
Hey yall, what is the spacing for the mounting holes on Doug's champ ot? I need a se ot with 2 3/8 spacing. Thanks
Re: Ot hole spacing
« Reply #1 on: October 09, 2012, 11:55:55 am »
Here's the page with the xfmr specs:
http://www.el34world.com/Transformers/fentrans.htm
Look's like the Champ OT (p/n#022905) has the 2 3/8" mounting you need
Re: Ot hole spacing
« Reply #2 on: October 10, 2012, 08:18:52 am »
I choose the OT I want and simply drill one hole and use one of the existing hole if it is a build.  If it is a restoration, that is a different story.  Most times you can just drill the hole in the OT mount, but if not another small hole in a chassis is no big deal.  Why sacrifice using the OT you want just because the holes don't align?  If this is not acceptable, you can always make a mounting plate that fits the holes in the chassis and drill 2 other holes for the OT.
Offline Stankfut
Re: Ot hole spacing
« Reply #3 on: October 10, 2012, 09:19:19 am »
ĄD'oh! I knew that Doug had that info on his site....i just couldn't find it :BangHead:. This is a restoration of sorts...cheap Japaneseamp from the late sixties. The ot mounts on the speaker frame....the chassis is really too small to mount the ot to it
