September 15, 2026, 03:14:32 pm
Hoffman Amps Forum image Author Topic: 6v6 ppp output tranny  (Read 6055 times)
Offline ernie_jr
  • gimme a banana
« on: October 21, 2012, 07:15:18 am »
Quick question,
How would 4 6v6'v in PPP like an output transformer with a primary of 6.6K?
Thanks,
Ernie
stratele52
  • Guest
Re: 6v6 ppp output tranny
« Reply #1 on: October 21, 2012, 09:00:44 am »
IMO there is no problem , Hammond transformer recommend  5K to 8K for 2 tubes , so 4 tubes and 6.6K will work with less power than lower primary.
Can I say you put 2 tubes for nothing ?
Why "ppp" for Push Pull ?
Offline ernie_jr
  • gimme a banana
« Reply #2 on: October 21, 2012, 10:50:21 am »
thanks for the reply. ppp= push-pull pair.
ernie
stratele52
  • Guest
« Reply #3 on: October 21, 2012, 11:45:58 am »
Hi ernie_jr
Push pull are always in pair.    But pair are not always push pull.
Your projet is PPQ
Push Pull Quad !  ; )
« Reply #4 on: October 21, 2012, 12:09:29 pm »
PPP = Parallel Push Pull or Paralleled Tubes Push Pull
so PPP = more than 2 tubes = 4 tubes - 6 tubes - 8 tubes and so on
PSE = Parallel Single Ended or Paralleled Tubes Single Ended
so PSE = more than 1 tube = 2 tubes - 3 tubes - 4 tubes and so on
« Last Edit: October 21, 2012, 12:12:07 pm by kagliostro »
« Reply #5 on: October 21, 2012, 09:18:37 pm »
3k3 to 4k would be more optimal for a parallel push-pull quad (  :l2: ) of 6V6s
stratele52
  • Guest
« Reply #6 on: October 22, 2012, 03:46:27 am »
+1
