September 08, 2026, 07:14:01 pm
Hoffman Amps Forum image Author Topic: Soldering old way in 9 lessons - Watch it you won't be disappointed  (Read 10696 times)
Offline The_Gaz
Re: Soldering old way in 9 lessons - Watch it you won't be disappointed
« Reply #1 on: March 03, 2013, 03:45:51 pm »
Really cool, thanks for posting. I learned a few things, and I though I was an "Expert!"
« Reply #2 on: March 03, 2013, 04:54:36 pm »
K, what led you to the PACE lessons?
« Reply #3 on: March 04, 2013, 12:59:55 am »
A guy in an italian forum where I'm a moderator found one of the link
as I like this kind of movie very much
and I thought might be of interest
I found all the links and I have posted also here
Don't you like ?
« Last Edit: March 04, 2013, 01:03:03 am by kagliostro »
« Reply #4 on: March 04, 2013, 08:49:49 am »
I like it very much. Those videos were part of a week long soldering course I attended in '73 at Robins Air Force Base. PACE is a well known name at depot level repair facilities. You're the first person outside of FAA or depot facilities that I recall mentioning them. There is some excellent material in those videos. Anyone that ever melts a blob of solder could benefit. Thanks for posting.
I was so impressed with PACE that a bought one of their repair stations back in the '70s. Still got it, although it will probably never see any more pcb work. And the minichine function has been far surpassed by Dremel.
« Reply #5 on: March 04, 2013, 09:34:40 am »
Ciao Steve
I'm glad you like the videos, thank you for the info about them
One thing
I don't understand <minichine function> and also google didn't hep me to understand
please, can you explain ?
Grazie
« Reply #6 on: March 04, 2013, 10:11:39 am »
"minichine" is a word made up by PACE to describe the motorized functions of the repair station.
The minichine output on the PACE is a mechanical output. It is directly coupled to a small high speed motor shaft inside the repair station. A handheld rotary tool connects to the minichine coupler. The rotary tool supplied with the PACE is the equivalent to a Dremel rotary tool, except the tool has no electrical connection. Instead, it connects to the PACE through a 3' long flexible shaft. The PACE rotary tool uses several different sized collets to hold a variety of drills, burrs, grinders, polishers, cutters, etc. All this was aimed at repairing/modifying pcbs.
The PACE minichine is more than a rotary tool though. The same motor that operates the rotary tool also operates a small air compressor/vacuum pump that can be used to operate some small sprayers for cleaning, etc, but more importantly, the vacuum pump operates the desoldering tool. The desoldering tool is the gem of this repair station. It's basically a temperature controlled soldering iron that uses hollow tips. The iron also has a vacuum hose attached that will pull air through the tip, IOW, it will suck solder. The hollow tips come in a variety of nozzle sizes to fit the job at hand. The largest tip will fit over one of Doug's turrets and will easily remove solder from the outside and inside of the turret simultaneously. The smallest tip fits over a transistor lead or IC lead for removing solder. An experienced tech can actually do depot level work in the field on single or double sided pcbs.
It's really quite a minichine! :grin:
« Reply #7 on: March 04, 2013, 10:19:09 am »
Many thanks for the info
really an All Purpose Station
I think I've never seen something like that :thumbsup:
Ciao
Offline Ghetto_Soundwave
« Reply #8 on: March 06, 2013, 09:35:14 pm »
The soundtrack in the videos sets the tone for the dude's 60's hair :worthy1:
« Last Edit: March 06, 2013, 09:37:49 pm by Ghetto_Soundwave »
