September 08, 2026, 03:49:11 pm
Hoffman Amps Forum image Author Topic: Ken: WHY must the heater be this way?      (Read 4838 times)
Offline Geezer
« on: June 17, 2005, 09:30:09 pm »
        > Ken: WHY must the heater be this way?
<< Prev Topic | Next Topic >>
Author  Comment
gammelnalle
Junior tube assistant
(2/23/04 5:10 am)
 In an answe resently you stated :
Ken:
EDIT: also make sure the heater wires are not cris-crossed on the power tubes. Make sure the same wire go to the same pin on each tube--say 4 to 4 and 5 to 5--Not 4 to 5 and 5 to 4.
I take your word for it , but I'm a curios dumb swede who always wanna know..... so WHY!!! ???
cheers from sweden
bluesbear
Hey get your own solder
(2/23/04 8:00 am)
 Re: Ken: WHY must the heater be this way?
 Maybe I shouldn't answer for Ken.. but here's what I understand of this:
Wiring the power tubes this way reduces the hum induced by the filament circuit. As I understand it, wiring the other way doesn't induce hum, the hum is already there. Wiring it correctly just reduces it. This is why a single ended amp like a Champ is harder (but not impossible) to make hum-free. There is only one power tube so there is no way to wire it the way you describe. If you ever read anywhere about the heaters being wired "humbucking", this is what they're talking about. I'm not sure why this works. I only know it does. I've tried it both ways just to prove to myself that it does.
How'd I do, Ken?
Dave
Edited by: bluesbear at: 2/23/04 8:05 am
coap01
(2/23/04 9:16 am)
 heaters
 This is the way i see it. The green wires even tho they supply same voltage/current, are 180 degrees out of phase. That means that when one wire is on the positive part of the sine wave, the other wire is on the negative.
You want the same wire going to the same pin because you want the tubes with be heates in phase...so to say.
umm so thats what makes sence to me, but i'm sure Ken will have a simple answer
--Lev
GroundhogKen
Forum Moderator
(2/23/04 11:25 am)
 Re: heaters
 If each power tube generates a certain amount of hum and each half of the push pull circuit has the same filament polarity, then the hum is cancelled at the output transformer.
It's that same old differential amplifier concept.
Which is pretty much what everyone stated above.
Ken
gammelnalle
(2/23/04 4:47 pm)
 Re: heaters
 Aaarg !!!
Its so very easy.... once you see it !!!!
Tanx a lot guys!!!
R8burst
(2/25/04 2:38 pm)
 heater wiring
 Could someone reference the original post that contained Ken's answer on this heater wiring question? I did a search but couldn't find it.
Tony
GroundhogKen
Forum Moderator
(2/25/04 7:33 pm)
 Re: heater wiring
 Someone had a thread about an amp with excessive hum. I suggested check the heater polarity on the power tubes.
I can't really take any credit for it--I was just spitting out what I had already read on Doug's Heater page.
www.hoffmanamps.com/fenderservice4.htm
Ken
 Topic Commands
Powered By ezboard® Ver. 7.32
