September 15, 2026, 07:52:58 am
Hoffman Amps Forum image Author Topic: B15S preamp  (Read 4056 times)
Offline rzenc
  • TUBES RULE
B15S preamp
« on: December 03, 2012, 10:35:36 am »
Bass player asked if it is possible to build B15S preamp only. His idea is to use it to drive mixing consoles and also a SS poweramp + Ampeg 810 :help:
Schems for REV C and REV D:
http://www.el34world.com/charts/Schematics/files/ampeg/Ampeg_B15S_RevC.pdf
http://www.el34world.com/charts/Schematics/files/ampeg/Ampeg_B15S_RevD.pdf
This guy already owns Alembic F-1X.
Have you tried such a thing?
What would be your considerations regarding such project?
My idea so far is to use complete schem from input jack to P.I. output and insert a A.C.C.F.  to provide lo Z outs.
Many thanks in advance for insights!
Best Regards
R.
Re: B15S preamp
« Reply #1 on: December 03, 2012, 06:20:39 pm »
Isn't this what the EXT AMP jack is for?
Hmmmm.... if driving a different power amp you may want another gain stage.
Offline rzenc
  • TUBES RULE
Re: B15S preamp
« Reply #2 on: December 04, 2012, 10:04:49 am »
Thanks PRR!
 I thought about ext jack as a mean to provide him an output jack for his rackmount korg tuner. So that it may be hooked fulltime without adding load to bass signal.
If I need to implement another gain stage to drive power amp, then Could I keep P.I. as is and adopt your suggestion as low Z outs? I know a picture is worth thousands of words but my pc decided to crash and I can't use/access schema Until it is good again...
I plan to use xformer balanced out for mixing board and leave AC C.F. for stage amps.
Thanks for your attention!
Best Regards
R.
Re: B15S preamp
« Reply #3 on: December 06, 2012, 09:10:58 pm »
I added a gain stage.
Stock, the design level at EXT AMP was like 0.4V. A standard PA rack-amp needs 1.4V-2V to get all the power you paid for. So I figured it had to be done.
