September 17, 2026, 06:32:15 am
Hoffman Amps Forum image Author Topic: Magnatone varistors  (Read 9152 times)
Offline Leevi
    • Rikstone
Magnatone varistors
« on: December 16, 2012, 02:57:23 pm »
Does anyone know what is the type of the varistors in the Magnatone Tonemaster circuit
and can they be replaced by some other components?
For more information see the Magnatone Tonemaster schematic below:
http://www.tdpri.com/forum/attachments/amp-central-station/53528d1278865473-building-magnatone-tonemaster-214-titano-custom-314-schematic-same-magnatone-213-jpg
/Leevi
Re: Magnatone varistors
« Reply #1 on: December 16, 2012, 03:19:52 pm »
Ciao Leevi
Unfortunately the matter isn't so simple
http://www.el34world.com/Forum/index.php?topic=14650.0
« Reply #2 on: December 16, 2012, 04:22:45 pm »
I have dreams of finding a big box of them. No luck so far
« Reply #3 on: December 16, 2012, 04:45:28 pm »
Instead of search with the term varistor I've done a search with the term Carbide Varistor (which are those we are looking for)
here the result
http://www.ebay.com/sch/sis.html?_nkw=Vintage%20Russian%20Silicon%20Carbide%20Varistor%20100V%201W%20Oty%208&_itemId=190632044975
Offline darryl
    • ValveTone Amplification
« Reply #4 on: December 16, 2012, 05:06:54 pm »
I have experimented with the Russian varistors - they do not behave quite the same as the "genuine" Magnatone ones.
http://www.guitargear.net.au/discussion/index.php/topic,31524.0.html
Offline Leevi
    • Rikstone
« Reply #5 on: December 17, 2012, 10:22:41 am »
It seems to be very challenging to find them.
Maybe ask here:
http://www.vibroworld.com/magnatone/index.html
I also found these pages:
/Leevi
« Reply #6 on: December 17, 2012, 11:11:28 am »
Albert sometime ago told
Everyone knows something is impossible, until comes an inexperienced who does not know and invents
so I'm hoping arrive someone that reinvents an old varistor with new components  :icon_biggrin:
Offline smackoj
« Reply #7 on: December 17, 2012, 01:24:22 pm »
a rusky tube is one thing, but a rusky varistator is a diff. animal fo sho!  what exactly does a varistor do, make the tremolo work?    :w2:
Offline jazbo8
« Reply #8 on: December 17, 2012, 08:30:58 pm »
A bunch of 3.9V Zeners paralleled with 2M2 to 10M resistor get pretty close, but still not quite. See Mr. Robbins' report -> http://dalmura.com.au/projects/Vibrato%20effect%20measurements.pdf
Jaz
Offline SoundmasterG
« Reply #9 on: December 18, 2012, 06:22:31 pm »
In the link kaligstro posted, I attached some pictures of the two types used in the Magnatones and a word document in the last current post that lists the specs for those particular varistors and others. Hopefully that info can help you locate something that will work.
Zack doesn't run Vibroworld anymore as a business where you can buy products, and he doesn't have any of those varistors anymore.
Greg
« Reply #10 on: December 18, 2012, 06:38:27 pm »
Very interesting pdf Greg
Thanks for sharing
« Reply #11 on: December 20, 2012, 09:45:50 pm »
You're welcome Kagliostro. Hopefully it is useful to people looking to make the Magnatone vibrato circuit.
Greg
Offline Steve_P
« Reply #12 on: December 21, 2012, 06:45:17 pm »
Check the magnatone/valco yahoo group. you can buy NOS from a guy on Ebay, or you can buy new production from England, but you'll pay for it...
Offline Leevi
    • Rikstone
« Reply #13 on: December 26, 2012, 10:38:17 am »
The curve seems to be pretty close to the original.
Do you have any wiring scheme for it. Is it just the zeners in serial. How should the resistors be connected? One per each zener or one  per chain?
/Leevi
Offline jazbo8
« Reply #14 on: December 26, 2012, 04:03:19 pm »
I have not tried this myself, but I think it's just a single resistor parallel with all the zeners connected in series. A lot of zeners!
Jaz
« Reply #15 on: December 26, 2012, 05:46:08 pm »
A lot of zener mean we require a lot of space
about price $ 10.00 I think is enough to have it
Offline Leevi
    • Rikstone
« Reply #16 on: December 26, 2012, 11:31:13 pm »
Low wattage zeners are quite small but still... I agree with you.
Another question is the number of zeners, 37?
I suppose it has a relation to the used voltage. 37 x 3.9V =144,3V,
could it be less?
/Leevi
« Last Edit: December 26, 2012, 11:33:17 pm by Leevi »
Offline jeff
  • Need input
« Reply #17 on: December 27, 2012, 10:02:14 am »
I finally took a hard look at that circuit in my search to understand phase shifters.
It's a pretty ingenious and eloquent design.
I'd really love to play with that circuit, If you do wind up getting the parts and building it, try a little experiment. Come up with a way to add back some of the dry singal to the vibrato signal and see how it sounds.
Vibrato singal + original signal = phase shifter.
