September 17, 2026, 11:54:08 pm
Hoffman Amps Forum image Author Topic: PT question  (Read 5040 times)
PT question
« on: December 26, 2012, 05:29:30 pm »
If a transformer has two identical voltage and current windings
is correct to assume that it can be used as a CT transformer ?
see this one as an example
http://www.antekinc.com/details.php?p=730
I think this can be done, on the contrary a CT transformer can't be used as a two separate windings transformer, correct ??
Re: PT question
« Reply #1 on: December 26, 2012, 05:38:01 pm »
If a transformer has two identical voltage and current windings is correct to assume that it can be used as a CT transformer ?
Yes, but phasing is important. Hook it up wrong and you'll have zero volts end to end rather than twice the voltage end to end.
Re: PT question
« Reply #2 on: December 26, 2012, 05:43:41 pm »
Thanks Steve
and is correct that a CT transformer can't be used as a double winding transformer ?
in other words, having a CT transformer is or is not possible to use two different diode bridges to rectify each single branch independently ?
Re: PT question
« Reply #3 on: December 27, 2012, 05:50:52 pm »
Not.
Offline drgonzonm
Re: PT question
« Reply #4 on: December 28, 2012, 01:11:41 pm »
My two cents.
Provide a schematic of what you are proposing.
Also, do you have the model number of the p/t you are proposing?
(I just can't get out of my mind polyphase applications).  My question, is how much different is K asking if I were to put bridge rectifiers on the two 120 legs of power going into my house, as that transformer feeding the house is a 120-0-120, (240 volts between legs)  (USA) If I live in an apartment, I could conceivably have 120-0-120 and 208 between legs.
My brain is in broken mode.  After reviewing getting 12 phases out of a three phase input,  (y-input, delta and y-outputs)
Re: PT question
« Reply #5 on: December 28, 2012, 06:34:48 pm »
I was thinking to some absurd rectify like this
Offline drgonzonm
Re: PT question
« Reply #6 on: January 03, 2013, 01:18:12 pm »
I with the center tap, only two diodes are needed.  Only reason for adding diodes in a series is to increase the voltage rating.
Re: PT question
« Reply #7 on: January 03, 2013, 11:04:51 pm »
In all three plans, half the diodes stay reverse-biased all the time. Useless.
Re: PT question
« Reply #8 on: January 04, 2013, 02:44:37 am »
Useless
For sure, they are absurd
