September 17, 2026, 01:39:21 pm
Hoffman Amps Forum image Author Topic: Pop goes the PowerAmp  (Read 4141 times)
Offline silverfox
« on: January 06, 2013, 01:19:44 am »
I have a 160 Watt Mosfet power amp with 4-12 B-52 speakers that came out of a B-52 cabinet. I was told the cabinet is rated at 480 watts RMS. The power amp is driven by an amp emulator. I forgot to shut the amp off today and when my daughter used the setup this afternoon- I was gone, she hit the power switch and everything came on. The emulator generates a power on output signal so basically she said there was a really loud pop. Louder then she had ever heard before.
I tried to determine if it sounds the same but at about 10% volume level this setup starts getting really loud. I've never had it past 25% so there's no easy way to test is short of taking it to a shop and having a spectrum analyzer listen to it.
Question- Do you think this damaged the speakers? Just assume it was a full 160 watt pulse of about 200 hz. What about the mosfet amp? The output of the amp is transformer based.
As usual, thanks for the consideration.
Silverfox.
Offline 6G6
Re: Pop goes the PowerAmp
« Reply #1 on: January 06, 2013, 08:03:47 am »
I don't know what is going on, but I'd say the output section and speakers must be OK, if it is getting really loud.
