September 18, 2026, 12:58:38 am
Hoffman Amps Forum image Author Topic: interesting faceplate materials ?  (Read 7656 times)
Offline worth
« on: January 09, 2013, 08:09:57 am »
Anyone one have a source for unique faceplate materials for DIY plates ? Such as this example of a "crushed glass" pattern....
Re: interesting faceplate materials ?
« Reply #1 on: January 09, 2013, 08:51:38 am »
Look to the material on the left of the image, seems to be the material you are looking for, or simply is the reverse side of the matirial on the right ???
http://sell.lulusoso.com/selling-leads/25853/plexiglass-mirror-sheets.html
Sometime ago I've seen a faceplate made with the material on the right of the image, it was very nice, it looks like a plexi faceplate, but instead of gold it was a very nice gray mirror
« Last Edit: January 09, 2013, 08:54:07 am by kagliostro »
« Reply #2 on: January 09, 2013, 10:44:33 am »
Not sure if they will have exactly what you may be looking for, but this is the supplier we use for some signage materials.
http://www.sign-mart.com/products/8/index.aspx
They stock loads of materials.
« Reply #3 on: January 09, 2013, 04:20:01 pm »
Keep in mind you could have a clear faceplate, with a material or color behind it to achieve the same look.
I've seen thin metalflake-looking adhesive material that reminds me of the 3 Monkeys stuff you showed; a piece of clear acrylic over it would capture the same look.
You could also paint a chassis under a clear panel. Any color, hammertone, metallic, etc.
I used that trick with my Standel build. The metal chassis is painted the overall color of the "panel" with a clear acrylic faceplate over it. The acrylic was reverse-engraved (which just put the engraved side closest to the chassis, and leaves a smooth surface to the touch), and lit from the edge to cause the lettering to light up. You can light it with normal pilot lamps or LEDs (I used blue LEDs)
Offline phsyconoodler
« Reply #4 on: January 09, 2013, 10:31:48 pm »
I
 Love to see your amp!
« Reply #5 on: January 10, 2013, 03:06:26 am »
Oh, it's really Very Cool
if you've never seen it, here it is
http://www.el34world.com/Forum/index.php?topic=14263.0
« Reply #6 on: January 10, 2013, 07:31:22 am »
Yeah, I'm gonna do another picture of that. My phone's camera sensor was easily overloaded by the LED light, and gives a color balance that was not what you see looking at it.
I was also gonna update that thread with some soundclips, now that I have a means of recording to my computer.
« Reply #7 on: January 10, 2013, 09:03:33 am »
 :wav:
             Brad      :icon_biggrin:
Offline fuzz
« Reply #8 on: January 11, 2013, 07:24:42 am »
that's really nice what you've done !
it'd be really nice if you could show how you managed to do that look.
the hughe and knetter front panels use the same kind of things. blue LED with plexiglass.
« Reply #9 on: January 12, 2013, 04:07:32 am »
But wait...it only goes to 9????  :huh:
(actually very nice HBP)
Offline SILVERGUN
« Reply #10 on: January 12, 2013, 08:35:15 am »
Awesome HBP!! :thumbsup:
If the face will be less than 16" wide,,,check this out:
http://www.warmoth.com/Blank-Stock-10-x-16-C862.aspx?s=Name ASC&p=1
There's enough there to cut multiple pieces from it if you think you'll need more than one!
If you want to use a circular or table saw to cut it,,,,make sure the blade is spinning in the opposite direction of how you would normally cut wood
(same method for cutting vinyl siding),,,so it doesn't chip
ALSO, for metal or plastic try: http://www.onlinemetals.com/merchant.cfm?id=181&step=2&top_cat=181
they do small orders and cut to size
« Reply #11 on: January 12, 2013, 10:50:23 pm »
Pics and explanation of the LED lighting of the control panel are posted back in my original 25L15 thread.
