September 16, 2026, 05:21:49 am
Hoffman Amps Forum image Author Topic: when I added the 25 uf bypass cap with the switch I used a 25uf 50 volt  (Read 3913 times)
Offline catnine
  • I am wordy and frustrating EAYOR
in parallel with a 2uf 25 volt cap . does that really matter what the voltage diff is?
Re: when I added the 25 uf bypass cap with the switch I used a 25uf 50 volt
« Reply #1 on: January 10, 2013, 09:12:25 pm »
Both caps have to be rated over 3V (for preamp stages).
Higher voltage rating costs more.
However in these values a 3V cap may be too small to handle (or be worth making). 25V and 50V are entirely fine if you can afford the cost and size.
