August 29, 2026, 12:20:02 pm
Hoffman Amps Forum image Author Topic: Fender 5D6A Find  (Read 49969 times)
Offline drgonzonm
Re: Fender 5D6A Find
« Reply #50 on: January 22, 2013, 04:28:03 pm »
I have been looking at several 5D6 bassman pics and found a 47M & 100K resistor coming off the 270K voltage dividers in the pic below. The 5D6A has a 10M & 220K combination. Cant verify the 5D6 feedback resistor yet. Im thinking it is 20K as is the 5D6A. It's in hiding just under the last PS cap pic. Still looking for differenced between the 5D6 & 5D6A
Good luck, determining the differences.  Regarding the feedback resistor,  I hope you have better luck than I have.   The only recommendation is to look at 5d6b chassis that are on a couple places on the internet.   The poor photos I have suggest that the resistor might have a green or first blue stripe.
Plexi, do agree, that there is no 220K resistor between the 10meg and ground?
« Reply #51 on: January 22, 2013, 05:45:09 pm »
I do agree. There is no 220K between 10M and ground. Does the missing 220K equate to less gain? If you blow the picture up real big you can see a faded red-black,orange for the feedback resistor which would be 20K.
« Last Edit: January 22, 2013, 06:00:11 pm by plexi50 »
« Reply #52 on: January 24, 2013, 02:25:26 pm »
Got the 5D6A recapped today with all Sprague capacitors. Not cheap for sure. Sounds pretty good to my ear drums on my bench testing 2x12 ext cab. Waiting for the red Jupiter Astron style tone caps to arrive. My camera is biting the dust. :worthy1: :worthy1: :worthy1: :worthy1:
« Last Edit: January 24, 2013, 02:43:17 pm by plexi50 »
« Reply #53 on: January 24, 2013, 02:56:17 pm »
Looking real good Plexi.
What's that great big cap on the far left end of the eyelet board? That's not the cathode bypass cap is it? 250uF@6v?
Have you used the Jupiter Astron caps before? If so how do they sound to you?
            Brad      :icon_biggrin:
« Reply #54 on: January 24, 2013, 03:06:45 pm »
250uf sprague bypass cap inside sleeve. I have the yellow Astron style un my 5E3. They sound very good to me. Full and warmy. Not brittle or muddy. Real vintage tone. If i keep the amp 6 months or more the caps will form there carbon path. Though that probably takes a year or so for a new tone cap to mature. Tone just gets better over time. I wish i had the original Astron power supply cap sleeves. I would have used the sleeves as and tucked each new Sprague inside. The 100uf bias cap is inside the amps original 100uf sleeve
« Last Edit: August 01, 2013, 03:48:24 pm by plexi50 »
« Reply #55 on: January 24, 2013, 09:22:06 pm »
I was taking more pics tonight to try and make out what the pencil script is on the tube chart. Then i saw the number 54 next to the chart in some kind of old magic marker or whatever they used. Now look real close at the pencil script on the tube chart. Im seeing
lf 1rst. Im trying to make out a name and cant put one together. So i am seeing lf 1rst. I know way back then they used to abbreviate the first of a product sometimes by using 1rst instead of (the first). And i believe with my eyes i am seeing lf before and seperated by 1rst. Maybe Kirst?
Say im not going mad! Please. Say it aint so.  :dontknow:
Also if you look at the numbers 5D6A on the tube chart you can see another letter or something to the right of the A before it was stamped. Maybe just goo?
« Last Edit: January 24, 2013, 09:44:54 pm by plexi50 »
« Reply #56 on: January 24, 2013, 10:02:39 pm »
Looks like K maybe not If?
          Brad     :icon_biggrin:
Offline rzenc
  • TUBES RULE
« Reply #57 on: January 25, 2013, 07:37:06 am »
I read first...
« Reply #58 on: January 25, 2013, 07:52:58 am »
k i r s t
--DL
« Reply #59 on: January 25, 2013, 08:02:58 am »
You're not thinking that handwriting means it's the first 5D6A to roll off the line???
Here's another likely scenario... Look at how it's written next to the tube placement chart. I think someone later wrote it there to indicate that the 5U4 is the 'first' tube in the line up.
The date code stamp "EC" would indicate 1955, third month.
« Last Edit: January 25, 2013, 08:05:17 am by sluckey »
« Reply #60 on: January 25, 2013, 06:13:09 pm »
Oh no not the first or anything like that. I was coming up with all kinds of interpetations as to what that pencil script was. The serial number has some meaning as to which number it was that rolled off the AL. Ive seen a lot of info online and it is all different as how to interpet the serial number. So at the moment i havent had time to break that down or know which info i am seeing online that is correct. In any case a once in a lifetime find for me. Got the red Astron style Jupiter caps installed tonight. Will plug and check all voltages in the morning
« Reply #61 on: January 25, 2013, 06:16:27 pm »
Got the red Astron style Jupiter caps installed tonight. Will plug and check all voltages in the morning.
What!!!! Dog gone you Plexi!    :cussing:
Now we gotta wait untill the morning to for you to tell us how that amp sounds?????     :BangHead:      :cussing:
            Brad      :laugh:
« Reply #62 on: January 25, 2013, 06:21:12 pm »
Yeah man im pretty wiped out. Im going broke buying those jupiter caps. $85.60 for the six of them. The amp deserves the best so i got to do it right. Im going to eat breakfast now!
396VDC plates with -43VDC grids
« Last Edit: January 26, 2013, 06:57:43 am by plexi50 »
« Reply #63 on: January 26, 2013, 11:59:12 am »
Voltages taken after 30 minutes warm up. Tryong 12AT7 tubes as i dont have any 12AY7 at the moment.  :worthy1: http://www.el34world.com/charts/valve/ValveData.php?e=view&f=14699
Edit: Voltages were taken again with 12AY7 V1 & V2. Voltage chart updated.
« Last Edit: February 02, 2013, 09:16:03 am by plexi50 »
Offline smackoj
« Reply #64 on: January 26, 2013, 12:17:56 pm »
That '55 fender is a real prize plexi! love almost anything from 1955 including Chevies with a modified V8 under the hood. lay scratch in 2nd and 3rd gear cruisin' past the malt shop....old guy's fun
 :icon_biggrin:
« Last Edit: January 26, 2013, 12:53:30 pm by smackoj »
« Reply #65 on: January 26, 2013, 12:29:53 pm »
Nice tone machine.  :worthy1:
What? That's it?      :m13
            Brad      :laugh:
« Reply #66 on: January 26, 2013, 01:46:59 pm »
SIR Willabe & Smackoj i couldnt be happier. (got a winning lottery ticket?)
Well i stole the 12AY7's from the 5E3 to test the tone difference in this bassman. I went back over and changed the tube chart voltages to what they should reflect on the schematic. Close enough. Wow! The amp definatley sounds sweet with the 12AY7's in V1 & V2. 12AT7 gain factor of 60 is too much in this amp. 12AY7 gain factor of 45 is the sweet spot. Now im lovin it. I hear another thing you can do is to change the 5U4G rectifiers out for 5Y3 rectifiers for an even more sweet spot. The PT for the 5D6 & 5D6A were the same. They used a 3300r bias resistor instead of the 6800r in it now using the 5U4G's. This is as far as i am going with the chassis. It's done and sounds great. No fiddling with 5Y3's or anything else. Man what a difference using the 12AY7's. My high gain days are over for the most part. Blues and low wattage is king for me. Next is to re tweed the cabinet and mount jensen P10R speakers.  :worthy1: :worthy1: :worthy1: :worthy1: :worthy1:
« Last Edit: January 26, 2013, 01:51:19 pm by plexi50 »
« Reply #67 on: January 26, 2013, 02:01:08 pm »
Well i stole the 12AY7's from the 5E3 to test the tone difference in this bassman. Wow! 12AT7 gain factor of 60 is too much in this amp. 12AY7 gain factor of 45 is the sweet spot.
That's great to hear Plexi. Glad to hear that all the hard work, love and care you put in that amp has paid off for you.
That amp after all was designed with the 12AY7, so it makes sense that it sounds great in there. I think distortion is overrated, but that's just me. I understand the need for sustain but.....
I bet that amp will rock if you can get the volume up to at least 6 or 7 even with the 12AY7 in it.
            Brad      :icon_biggrin:
« Reply #68 on: January 26, 2013, 02:15:51 pm »
I am using a 2x12 cab to test the amp with so the tone will be heavenly when it is mounted in the cab using 4 10" jensen speakers. I love a good 4x10 cab
« Last Edit: July 25, 2013, 02:15:59 pm by plexi50 »
« Reply #69 on: January 26, 2013, 02:18:18 pm »
Oh yeah! The distortion is very nice and ramps up slowly and evenly as you turn the volume up all the way to 12. Not all in your face at once.
Nice.
I bet that amp would be great for playin slide.
            Brad     :blob8:
« Reply #70 on: January 27, 2013, 11:53:30 am »
Im going to use my most unfavorite word i have heard in life. Im Confuuuuused. Heres my confusion:
Bassman 5d6a serial number info as i have found it says the folowing:
Bassman 5D6A (tweed)
0100 to 0200 = January-May/1955 = 5D6A
But mine has a serial of 0823 and tube chart with matching 0823  EI March 1955
All the parts in the amp are dated 1954. So whats the skinny on the serial number?
« Reply #71 on: January 27, 2013, 01:03:58 pm »
I have 1 or 2 of those big Fender amp books, let me see if I can find anything in them that might help.
            Brad      :icon_biggrin:
« Reply #72 on: January 27, 2013, 02:01:59 pm »
Ok, here's something. From Tom Wheeler's "The Soul of Tone, Celebrating 60 Years of Fender Amps".
Page 170 has a pretty good large (half page) photo of a well kept 5D6. But you can't really see the pot wiring. Caption under photo Say's; most should be 55's but the tube chart on this amp is stamped DL, which indicates Dec. 54 (0077). Say's there's another that is dated Nov. 54.
Book lists photo credit to John Peden.
You should try to get in touch with both of these guys. They might be able to help you or lead you to someone who can.
I'll look for info on serial #'s and dating.
             Brad      :icon_biggrin:
« Last Edit: January 27, 2013, 02:19:16 pm by Willabe »
« Reply #73 on: January 27, 2013, 02:30:48 pm »
Thanks Willabe. I have an Aspen Pittman volume 3 book. It has every amp and schematic in it except the early bassman amps. It starts at the 5F6A. There was so much going on back then that god only knows what the real info is on the 5D6 and 5D6A amps  They could be a mixed bag of all of them for all i know.
All my parts are dated 1954. 0823 is the serial number which does not fall into any of the bassman serial# catagories. This is getting weirder by the minute/
I also read some where last week that the earlier Bassmans used a very thin baffle board and when certain bass notes were hit the baffle board and speakers would flex back and forth. This baffle board is very thin and measures 1/4" thick. Very thin
Found little EC stamps around the inside of the cab
« Last Edit: January 27, 2013, 04:02:10 pm by plexi50 »
« Reply #74 on: January 27, 2013, 04:04:54 pm »
That's probably where some assembly dip was testing the stamp for ink before actually stamping the tube chart.  :l2:
« Reply #75 on: January 27, 2013, 04:23:23 pm »
:l2: :l2: That makes sense. Does this make sense?  0823 /  #82 off the AL. March (3) 1955?
Edit" I just found this Bassman amp dating on the Greg Gagliano Fender amp dating site. It says:
Bassman 5D6, 5D6-A (tweed)
   0600 to 0900 - 1954
« Last Edit: January 27, 2013, 06:33:44 pm by plexi50 »
« Reply #76 on: January 27, 2013, 10:07:33 pm »
It might be the woman who wired your amp up.
I had a '55 Tremolux with a small piece of tape inside the chassis between the tube sockets, which let me know it was wired by Eileen. Maybe "Kirst"en wired up your amp. I didn't notice the piece of tape with a name in your chassis.
No, because the number on the tube chart is simply the number that's already stamped on the chassis. I seriously doubt the chassis stamping was done at the end of the line; more likely when it was an empty metal shell.
Which means what I've always said: don't read too much into the serial numbers. It is commonly seen in Fender guitar serial number charts that some ranges of number overlap years and/or guitars have numbers which fall outside their supposed year range. Those charts are generally compiled by observation rather than a set of rules.
You're very much better off noting the two-letter date stamp and comparing that with other features in the amp. At least, that was the gold standard for dating tweed Fender amps when I got out of the vintage game in 2000.
Seriously, forget the frickin serial #'s because I never knew a dealer who put any stock in them (unless they were trying to reel you in and you seemed excited by a serial number). Nashville had a number of vintage guitar shops, and I went to a LOT of shows back before 2000 including a number of very large shows in other states (like the Chicago show, Dallas show, etc) both as a buyer and as help for some friends who were vintage dealers.
Don't do that. If you need to tinker, yank a single 5U4.
I haven't found info to state when the 5AR4/GZ34 was introduced, but between tube data sheets and Fender schematics it seems to have come out some time around 1959.
This was a bass amp, and you didn't want sag when you played the low E on your Fender Electric Bass. The 5U4 had the highest current capacity and generally the lowest voltage drop of the 5v rectifiers before the GZ34 was available, and it seems Fender experimented using a pair of them to reduce the voltage drop (because a single 5U4 would handle the current requirements). Fender even used the mercury vapor 83 in the 5F6 Bassman to try to reduce sag even more; after the initial voltage drop a mercury vapor rectifier has very little voltage output change with changing current.
Given Fender used the European designation on its schematics and tube charts, I can't help but wonder if they had tubes pitched to them by the same Philips/Amperex USA folks that were selling ECC83's and EL84/EL34's to U.S. hi-fi manufacturers. Or maybe they were reading industry mags of the day and seeing other manufacturers using the Euro tubes.
I dunno, I guess you can use two 5Y3's, but low sag/hum was the intent of this amp series pretty much from the beginning.
« Last Edit: January 28, 2013, 08:37:02 am by HotBluePlates »
« Reply #77 on: January 28, 2013, 08:26:16 am »
Thanks HBP for your wisdom. A little excited on this end to even have it sitting here. Wish it could talk. No tinker on this one. It's finished and needs to go back in it's wooden condo. I may pull a 5U4 later down the line when it is actually back in the cab with the 410 speakers to see if i can hear any diff. I didnt find that little piece of tape with a name on it like i found in the 5E3. All in all it is one clean puppy.
« Last Edit: February 14, 2013, 05:56:55 am by plexi50 »
Offline drgonzonm
« Reply #78 on: January 30, 2013, 05:23:01 pm »
I am glad you rebuilt that puppy.  Its your amp, you try the 5y3's and the bias  change if you want.  If you remove that 220K resistor, tell us how it sounds.  It would not surprise me that it has a different tone.   :m7
« Reply #79 on: January 30, 2013, 08:04:26 pm »
Under noraml amp circumstances i would remove the 220k going to ground,change the VD run off resistors from 10M/220K to 4.7M & 100K. But i cant bring myself to start mesing with this amp. The worst part is i may never know what the tone difference is and that in itself is a sin. I could do it and it would not look tampered with after i was finished. Thats the million dollar question: To tamper or not to tamper. It is beautiful.
Let look back in this thread on page one and see what Geezer had to say:
Cathodyne inverter.......and 12AY7 in V1 & V2, dual recto, 10Meg local feedback....wow, 2 gain stages, CF, then another gain. I'll wager that thing rocks!
Without tampering with the amp can we get an approximate idea of what the tone may be like by comparing the 10M vs the 4.7M local feedback and omitted 220K to ground? Smoother,More rounded,Less breakup,different kind of clean and breakup. The tone math may be endless unless actually heard
And lastly i just dont have an SM57 mic to make sound clips of any good quality. We all would want to hear the differences at 3-5-7-8-11 O'clock
« Last Edit: January 30, 2013, 08:17:08 pm by plexi50 »
« Reply #80 on: February 02, 2013, 08:16:54 am »
I have a power tube question:
The schematic says 6L6G tubes. Tube data says 360VDC max. Did Fender possably not print the power tubes 6L6GC on the schematic or layout ? I see a lot of these amps online using 6L6GC power tubes. They can handle much higher max plate voltage.
Those old coke bottle 6L6-G tubes have a tone all of there own
« Last Edit: February 02, 2013, 08:20:57 am by plexi50 »
« Reply #81 on: February 02, 2013, 09:01:01 am »
I think it's more likely that Fender 'ignored' the tube data.
« Reply #82 on: February 02, 2013, 10:44:06 am »
That make perfect sense. The Deluxe reverb is a good example of that using 6V6GT tubes rated at only 350VDC with 415VDC on there plates
« Reply #83 on: February 02, 2013, 10:55:41 am »
They could have started testing/shipping their amps at that point with 6L6GB's and wanted to use up the old tube charts.
          Brad     :icon_biggrin:
« Reply #84 on: February 02, 2013, 03:47:05 pm »
          Brad     :icon_biggrin:
CBS 6L6GB is what came with it when i got it. The date code on them is 6043
« Reply #85 on: February 15, 2013, 06:07:05 pm »
Just found the choke number on the winding paper. Very hard to see and hell to get a decent pic of. But here it is. Choke # 14597
« Reply #86 on: February 15, 2013, 11:58:29 pm »
Or they asked RCA if it would work, and were given the thumb's up.
Remember, earlier data sheets had conservative ratings intended to second-guess your design as well as line voltage variations. Later Design Maximum ratings with higher ratings put the load on you to second guess your design and line voltage variation. The exact same tube would appear to have higher ratings under the later system.
And for the most part, plate voltage ratings appear to be about the closeness of pin spacing and the dielectric strength of the plastic in the base. An 807 has a higher plate voltage rating that 6L6GB just because the plate connection is at the top of the tube instead of next to the other pins. The guts are exactly the same as the 6L6 version.
« Reply #87 on: May 29, 2013, 08:03:00 am »
I am almost finished with the bassman. I bought 4 Weber alnico 10S speakers. What a long road*
« Last Edit: May 29, 2013, 08:06:38 am by plexi50 »
« Reply #88 on: May 29, 2013, 08:23:10 am »
I saw a webpage intended for radio restoration folks, which showed how to take a modern part and encase it in either molding wax or epoxy to simulate the size, shape and appearance of old-style parts. Restoration guys tend to have no faith in the old parts (they know they almost universally fail over time), and go so far as to create the old labels to put on their simulated parts to ensure a radio looks 1930's-new again.
I'm thinking of getting a couple Jupiter caps just to cut them open and see if they're doing the same thing: using a modern (say, polyester film/foil) cap and just encasing it in a package to look like an old Astron.
« Reply #89 on: May 29, 2013, 11:33:19 am »
Snake oil? Hmmmm.......    Could be.
                      Brad       :laugh:
« Reply #90 on: May 29, 2013, 01:09:11 pm »
Makes you wonder. I remember a thread a few years ago about someone cutting open a Sprague Atom power supply cap and finding i believe something the size of an Illinois cap inside. Let me know if you really open one up.
« Reply #91 on: May 29, 2013, 02:18:58 pm »
Lookin' great there plexi. You got some sound bytes?
« Reply #92 on: May 29, 2013, 03:50:41 pm »
Sluckey did that. What's inside is even smaller than an Il. cap.
                Brad     :icon_biggrin:
« Reply #93 on: May 29, 2013, 05:30:07 pm »
Speakers wired up. I have a good feeling about how this is going to sound with these 10" speakers.
« Reply #94 on: May 29, 2013, 08:49:03 pm »
Also: the data-sheet ratings cover ALL services. Military radio, broadcast transmitters. (Yes, broadcast and mil users were supposed to use different part numbers, but....) If a broadcast transmitter quits, it could be $1,000/hour of lost ad income. If a military radio quits many things can go real wrong.
Compared to that, the "importance" of a bar-band is very small. If the guitar amp quits, the barkeep runs the jukebox while the band calls-around for another amp.
It's like: can a One Ton truck carry 3,000 pounds? If it's one load of hogs 10 miles once a year, yes it can. If it is a brick delivery truck working 6 hours a day 300 days a year, a 50% overload will result in early and frequent break-downs. OTOH if a 1.5-Ton truck is a LOT more expensive, a low-cash operator may choose to overload a 1-Ton and replace bearings and gears every few months.
And in particular: original 6L6 had a 400V number, but they had trouble with the *base* breaking down. Later sheets showed 360V. Even after improved base materials came into use.
« Reply #95 on: May 29, 2013, 10:34:41 pm »
Just letting you know, that if they're new Webers, they'll need breaking in for a while. New Webers can sound a bit harsh straight out of the box.
« Reply #96 on: May 30, 2013, 03:41:08 pm »
I have a 3/8 jack cord running from my stereo out that i plug into the input jack of an amp or to the speaker alone and just leave it on 8-12 hours everyday for a week.
« Last Edit: July 25, 2013, 02:17:51 pm by plexi50 »
Offline Platefire
« Reply #97 on: May 30, 2013, 05:21:40 pm »
Very Very nice! I haven't been following the progress of this since you got it but today kind of caught up. Great Job! I'll never forget the first vintage bassman I ever heard back in the 80's at an outdoor concert. This guy was playing a tele and it just sounded awesome--it made a lasting impression on me. I love all the old fender factory history too. Something about a vintage fender amp that's pure Ameriacan/USA more than any other amp to me. I treat every ventage Fender that comes in my door with great respect. I know your proud of it, congradulations! Platefire
On the right track now<><
« Reply #98 on: May 30, 2013, 06:41:18 pm »
Yes that looks tweed-tastic!
« Reply #99 on: May 30, 2013, 07:20:28 pm »
I didnt think i would ever get it all finished. It will look even better in a few months after it gets a tan and some wear. And in a few weeks those speakers ought to be broke in good.
« Last Edit: July 25, 2013, 02:18:28 pm by plexi50 »
