September 16, 2026, 12:06:40 am
Hoffman Amps Forum image Author Topic: any useful reason to change power transistors in a Randall RB60?  (Read 7152 times)
Offline smackoj
I have a late sevenites Randall RB 60 watt bass amp. I have replaced the orig. 15 inch spkr with a better quality one and I have done a thorough cap swap-out on the board. It runs quiet and smooth and has nice tone and there's no real urgency, but I would like an opinion on changing the power transistors. It uses 2 of the metal lay down type trans. to put out about 30 watts each. Does it make any sense to try and find a set of replacement trans. that have a higher amplification? In other words, can I make this amp stronger with just a simple transistor swap? Or, does that create a whole chain of events where all the up or downstream values on parts need to be changed too?
thanks in advance amigos
 :icon_biggrin:
Re: any useful reason to change power transistors in a Randall RB60?
« Reply #1 on: January 13, 2013, 10:38:21 pm »
No, you will not get more power. The transistors just pass power, don't "make" power.
Do NOT mess with healthy power transistors. This usually ends badly.
Offline smackoj
« Reply #2 on: January 14, 2013, 07:37:24 am »
roger that PRR
