September 08, 2026, 12:10:59 pm
Hoffman Amps Forum image Author Topic: Fun with magnets....turning cheap pickups into gold  (Read 7900 times)
Offline Geezer
« on: January 15, 2013, 09:41:55 pm »
I wanted to try some new pickups, but hate spending $$$ on something I have no idea if I will like. Duncans and Dimarzios are $150 a set and up, with "boutique" winders costing $250 to $400 a set!!! :sad2:
I had heard about switching in different magnet types, and thought I'd give it a shot on some cheap humbuckers.
I bought some "Dragonfire" pickups (made in Korea, potted, alnico magnets) and "Uncle Willie" pickups (claims he hand winds them, but the parts are Korean, unpotted, ceramic magnets) off of eBay for about $30 to $40 a set. I chose them for price, but also because the DCR was approximate to PAF values (7.5k to 8.5K). Some brands have overwound bridges (16K & up) and I did NOT want those. I also needed gold covers, which both of these offered for low $.
I found a seller on eBay that specializes in PAF style magnets (seller: addiction-fx)....they cost about $2.50 each, and each pickup uses 1x magnet. I ordered some Alnico 5, 4 and 2 to try. They are rough cast, unpolished....just what are recommended for PAF. You can get them "oriented" or "unoriented" for different flavored tone. Do some google searching & you'll find descriptions of the different magnets and the tones they produce. They are also 2.5" long, something I will talk about later.....
I first installed the pickups "stock" to have something to compare to. Both sets were pretty bland, nothing to write home about.
Swapping the magnets is pretty easy, you just need to be careful of the wires, but the magnet just slides right out after disassembly. If the pickup is potted, you may have to work a little to loosen up the magnet from the wax, but it's fairly easy to do. There are youtube videos that are helpful, and there are threads on some of the guitar forums (mylespaul.com, etc) that give some guidance. Take care to observe how the magnet comes out of the pickup, keeping exactly in the same position so you can match up the new magnet's orientation. NORTH is marked on the new magnets, and thankfully it was also marked on the stock units. If you get it wrong, the pickups will be out of phase when combined, & you'll have to take one of them out & flip the magnet around until you get it correct. There was also some guidance for this on some of the guitar forum threads I found.
I've got it down to a fairly quick procedure.....I can loosen the strings, remove the pickup, disassemble and swap the magnet, reassemble and reinstall in about 5 minutes!
About the length of the magnets....all the cheap, stock pickup magnets were ~2.25" long....about 1/8" too short on each end of the pickup. The 2.5" new magnets filled the space in the pickup completely....very nice!
I put an A5 magnet in the neck, and an A2 in the bridge.
After tuning the guitar and doing a preliminary adjustment of the pickup height, the difference in tone was evident from the 1st note....full, round notes with a sweetness the stock magnets didn't have. I adjusted the pickups for balance of volume when switched, and I really couldn't be happier! I can't imagine "boutique" pickups sounding any better!
I am going to try the Alnico 4 mags, and also try the A5 & A2 in other positions to see where I like each type the best
Another note: I have found that I like covered pickups MUCH better than those with bare, open bobbins. The covers give a smoothness and evenness that I like, none of the harshness of uncovered. When I was a kid, it was all the rage to take your pickup covers off, and I just got in the habit of it, or always bought uncovered models. I also noticed that most, if not all, of the pros whose tone I admire use covered pickups......live & learn
Anyway, for about $70 to $80 max, I have 2x very nice sets of "custom" pickups, and I'm having a bunch of "cheap" fun!
Geezer
« Last Edit: January 16, 2013, 06:44:34 am by Geezer »
Offline Geezer
Re: Fun with magnets....turning cheap pickups into gold
« Reply #1 on: January 17, 2013, 04:36:38 pm »
Update for those who care, which is obviously nobody!  :laugh:
I tried all the magnets I have in my es336/339 clone, and settled on A2 in both the neck and bridge. Perfect tone for this guitar. I'll save the other types for experimenting on another guitar in the near future
So glad I didn't drop hundreds of $$$ on SD's or Dmzo's. According to all I read, and the "tone charts", I shouldn't like the A2 mags, and they would have been the very last type I would have ordered to try  :dontknow:
G
Offline pullshocks
« Reply #2 on: January 18, 2013, 08:11:39 am »
Cool stuff Geezer.  I am DIY to the max on guitars and amps but never had any temptation to mess with pickups, other than.....taking the covers off...yes it was definitely the rage.  :worthy1:; I also re-wired my T-tops to 4 conductor, I'm sure that took $$ off the resale  of these now-somewhat valuable pickups.
Did you ever post any pictures of the guitar you are talking about?
Offline Tom_Hull
« Reply #3 on: January 18, 2013, 10:00:13 am »
hi
sounds good,, thanks
tom
Offline Geezer
« Reply #4 on: January 18, 2013, 01:07:43 pm »
No, but I will as soon as I get the chance....I gave into temptation again at the pawn shop and got another $150 gem.
G
Offline Geezer
« Reply #5 on: January 18, 2013, 01:40:35 pm »
Here'tis....very smooth player, late 90’s to early 2000’s Korean made
« Last Edit: January 18, 2013, 01:44:22 pm by Geezer »
« Reply #6 on: January 31, 2013, 05:23:39 am »
Just saw this thread. This is interesting. Never have thought of doing that?
THANKS for sharing your experience!
Offline jeff
  • Need input
« Reply #7 on: January 31, 2013, 03:36:47 pm »
Here's an idea :think1:. How 'bout an electro magnet?
 That way you could turn it up or down by making the electro magnet field stronger or weaker.
Good Idea, though. I have a PU that sounds bad, I'll try swapping the magnet first before buying a new PU. I guess it depends on the coils/wire gauge/# of windings too but it's worth a try.
 Jeff
