September 13, 2026, 07:28:36 pm
Hoffman Amps Forum image Author Topic: amp blowing fuses  (Read 6697 times)
Offline ernie_jr
  • gimme a banana
amp blowing fuses
« on: January 18, 2013, 02:05:40 pm »
I need some help. My ampeg build with the 807s has started blowing fuses. Was working fine til one day turned it and fuse blows. I have taken out all the tubes so nothing is still hooked up, fuse still blows, so it seems as if the PT went bad. Before I put in a new one, what do I need to check so I dont fry a new PT. All the parts in the amp are new except some of the tubes.
Any advice will be a help.
Ernie
Re: amp blowing fuses
« Reply #1 on: January 18, 2013, 02:31:19 pm »
Does it use a SS rectifier? If so, disconnect the HT leads from that. Still blow fuse? Post a schematic.
Offline ernie_jr
  • gimme a banana
« Reply #2 on: January 18, 2013, 03:11:44 pm »
Tube rectifier, no schematic, but it is basically an ampeg B15
Ernie
« Reply #3 on: January 18, 2013, 03:33:07 pm »
How quickly does it blow the fuse? Immediately when you flip the switch? Several seconds later? Disconnect all secondary leads. Still blow? If so, disconnect the PT primary. Still blow? If not, you probably need a new PT.
« Reply #4 on: January 18, 2013, 03:40:41 pm »
Ampeg B15 is a great amp.
Offline ernie_jr
  • gimme a banana
« Reply #5 on: January 18, 2013, 06:21:15 pm »
Fuse blows within 1 sec. Hum in PT just before it blows. All secondary leads have been disconnected. If it is the PT, what would cause it to blow? It has been used less than 50 hours. It is a Fender replacement 022798 bought from Antique Electronics.
Ernie
Offline ernie_jr
  • gimme a banana
« Reply #6 on: January 18, 2013, 06:23:55 pm »
http://www.el34world.com/Forum/index.php?topic=14573.0
if this link works, this is the amp with the problem.
Ernie
« Reply #7 on: January 19, 2013, 03:48:37 am »
My two cents
have you tested electrolytic capacitors ?
stratele52
  • Guest
« Reply #8 on: January 19, 2013, 06:04:06 am »
Ernie
Fuse blow with ALL  secondary lead disconnect from the amp ; Transformer is short.
Why ? Amp need too much current.
1- Problem in the circuit ?
2- Not the good transformer for your need  ? Its a Bandmaster transformer 325 v at 200 ma , heater ; 6.3 V at 4A and 5 V at 3A .  I don't check your tubes need.
3- Fuse too high to protect transformer if circuit come defect ?
« Last Edit: January 19, 2013, 06:21:17 am by stratele52 »
« Reply #9 on: January 19, 2013, 06:13:56 am »
For sure, but why ?
stratele52
  • Guest
« Reply #10 on: January 19, 2013, 06:48:13 am »
For sure, but why ?
ernie jr must do some check as I write . You want details ?
Problem in the circuit ; Too much heater current need ( I don't check tube's spec)
Bias too hot , over transformer spec .
Filter caps defective; I see cheap filter caps in this circuit board
Short to ground , building error.
Short output transformer / wrong speaker load.
Some test with current limiter whit a new transformer is a must . We must do that with a new build amp before.
Offline ernie_jr
  • gimme a banana
« Reply #11 on: January 19, 2013, 07:55:03 am »
Thanks for the input.
 PT is 200ma at 325 volts. All caps are brand new, same ones I use in my Sunn builds and never had a problem. Heater current 3 preamp tubes 2 807's, way below PT rating. 6.3 volts at 4 amps, 5 volts at 3 amps. Dont think there is a short in the building as the amp was working fine for several weeks. Bias is (was) set to specs.  I am hoping that the 5v4 shorted out and that is what caused the problems. I hope to get it checked sometime next week.
Thanks.
Ernie
« Reply #12 on: January 19, 2013, 08:23:51 am »
likely what happened or a cap fail-short taking out the recto and PT. did you install a B+ fuse?
btw, test the 807's, OT, and the rest of the power rail as well.
--DL
