September 13, 2026, 01:16:48 pm
Hoffman Amps Forum image Author Topic: Is this Schematic correction right?  (Read 6171 times)
Offline frank57
« on: January 23, 2013, 02:04:56 pm »
Just want to get this Hiwatt schematic more accurate.
Is the OT CT in the wrong place on the original?
It should be behind the 100 ohm resistor?
stratele52
  • Guest
Re: Is this Schematic correction right?
« Reply #1 on: January 23, 2013, 02:15:36 pm »
IMO your red pencil line is the good one.
I look only the scematic
« Last Edit: January 23, 2013, 03:07:14 pm by stratele52 »
« Reply #2 on: January 23, 2013, 02:18:15 pm »
I would say no, not if the schematic and layout drawing line up the same.
Notice how they "T" off a 470R going to 2 @ 100R for the screen grid B+ node?
But 5w/100R might not be enough of a safety margin. If not then the problem is can you get a 10w to fit on that PCB?
              Brad      :icon_biggrin:
« Last Edit: January 23, 2013, 02:27:02 pm by Willabe »
Offline frank57
« Reply #3 on: January 23, 2013, 03:43:40 pm »
So it was wrong on the original schematic?
I can probably cram a 10 watt in there.I don't think the dissipation is that great there.
Looking at the phase splitter I think if you readjust the parts you get something that makes more sense although it might not be exactly what they did.At least on most Hiwatt schematics that's where you would find those values.
I assume they're performing the same function here.
stratele52
  • Guest
« Reply #4 on: January 23, 2013, 03:59:26 pm »
IMO 5 watts is enough.
« Reply #5 on: January 23, 2013, 04:56:58 pm »
No I'm not saying that. I'm saying that the schematic could be right. I would compare the schematic to the layout drawing. If there are the same it's probable right. I can't make heads or tails out of that PCB layout drawing.
Stratele is probably right. He's much better at the math than I am.
                Brad     :icon_biggrin:
