September 13, 2026, 09:47:10 pm
Hoffman Amps Forum image Author Topic: another SUPER REVERB sick  (Read 9619 times)
Offline Colas LeGrippa
  • MAKE LOVE NOT WAR
« on: January 25, 2013, 04:50:31 pm »
Hi !
This is THE month of Fender amps for me. I have spent nearly 2 days on this one. The reverb is feeding back with a high squeal when the  reverb volume is set at 7 and up. The tremolo works fine but the voltage on the plates of the trem is WAY over what the schem shows. The B+ before the 220K is supposed to be 460V and 250V after, I get 436V after, so the drop is not enough for some obscure reason ! It seems this amp was modified. The power tubes grid leak resistors are 220K, PI plate resistors are 47K each, at least 2 caps were added with no report to the schem. Anyway, the voltages are good except on the trem tube .
Thanx ( and happy week-end ! )
Colas
P.S.: call me Alvin.
Re: another SUPER REVERB sick
« Reply #1 on: January 25, 2013, 06:05:29 pm »
I wouldn't worry about the trem. I'm thinking the plate voltage is high because you don't have the footswitch plugged in and the trem engaged while taking that reading.
« Reply #2 on: January 25, 2013, 06:10:34 pm »
The B+ before the 220K is supposed to be 460V and 250V after, I get 436V after, so the drop is not enough for some obscure reason!
That tube isn't drawing any current, so no voltage drop across the 220K plate R.
Could be, bad tube, heaters are not lighting up, bad scocket, dirty scoket/tube pins, cathode connection to ground or it's KR is bad.
           Brad      :icon_biggrin:
Edit; I was writing while Sluckey posted. I'd try what he wrote first.
« Last Edit: January 25, 2013, 06:12:35 pm by Willabe »
  • MAKE LOVE NOT WAR
« Reply #3 on: January 25, 2013, 08:16:07 pm »
thanks guy , I will verify that and get back to you
I love you, bros.
colas
  • MAKE LOVE NOT WAR
« Reply #4 on: January 26, 2013, 07:08:40 am »
I wouldn't think so since the trem works fine !
« Reply #5 on: January 26, 2013, 12:17:20 pm »
You didn't say that.     :laugh:
Then it's gotta be what Sluckey said.
            Brad     :icon_biggrin:
Offline 6G6
« Reply #6 on: January 26, 2013, 01:37:19 pm »
If the trem is working, then the tube should be drawing current.
Could the 220K be more like 220?
  • MAKE LOVE NOT WAR
« Reply #7 on: January 26, 2013, 04:33:42 pm »
no, I thought of that too so I unsoldered one leg of that resistor to make sure it had the right value
« Reply #8 on: January 26, 2013, 05:12:57 pm »
Did you try what Sluckey said to try?
             Brad      :icon_biggrin:
  • MAKE LOVE NOT WAR
« Reply #9 on: January 26, 2013, 07:23:37 pm »
no, because I don't have no footswitch :w2:
I have though plugged in a rca connector to act as one
Colas
« Reply #10 on: January 26, 2013, 08:26:01 pm »
Ok, and did you take a voltage measurement then?
                  Brad     :laugh:
  • MAKE LOVE NOT WAR
« Reply #11 on: January 26, 2013, 09:52:51 pm »
Yes I had. THe voltage swings so fast I just can't measure it but my meter has an average function and it indicates 450 or so volts. One the LDR side, other plate is 100V or less volts, but still too much according to the schem.  I have very poor understanding of a vibrato and LDR circuits. One thing is sure: the goddam voltage is too high. But the main issue is the reverb that starts to squeal / howl like a mic feedback when the reverb control knob is set past 7. And I am wandering if the trem tube HV and the reverb issue are not related.
Thanks bro.
« Reply #12 on: January 26, 2013, 10:14:15 pm »
Sorry.    :dontknow:
               Brad    :icon_biggrin:
« Last Edit: January 26, 2013, 10:18:51 pm by Willabe »
  • MAKE LOVE NOT WAR
« Reply #13 on: January 27, 2013, 08:27:06 am »
no prob, thanx for help ( or some sort of....... :l2:)
« Reply #14 on: January 27, 2013, 08:45:15 am »
Well I'd try swapping out the verb tank with a known good one. I'd also try taking the verb tank out of the speaker cab and make sure the speakers are not causing the problem by shaking the verb tank.
I'd also try swapping the 12AT7 verb driver tube and the 12AX7 recovery tube with known good ones 1 at a time. If that don't fix it, I'd try chop sticking it to see if a wire is in the wrong place. Grid wire being most important, keep it away from plate wire.
I'd probable try swapping the tubes 1"st.
I didn't say these before cause I was thinking you already did these tests.
            Brad     :icon_biggrin:
« Last Edit: January 27, 2013, 08:55:32 am by Willabe »
  • MAKE LOVE NOT WAR
« Reply #15 on: January 27, 2013, 03:58:08 pm »
I did not swap the reverb tank because I didn't have a spare one. The tubes though were replaced at least twice with no effect.
I will order a new tank from Doug, since this one has no plastic cloth cover anyway and I suspect it to be defective.
Thanks, Brad Pitt
Offline phsyconoodler
« Reply #16 on: January 27, 2013, 04:44:23 pm »
Doubtful. Take a real close look at the reverb components on the board and make sure there are no burnt,open or severely drifted resistors.
  Then check the wire from the reverb pot to the board and add a shielded one just to check the result.
Throwing parts at this amp will not fix the reverb.
Offline Cork
« Reply #17 on: January 27, 2013, 07:33:51 pm »
I am having same problem with Showman head.
456V before 220K resister in vibrato circuit, and 450V after, at pin #1 of V-3.
No reverb however.
But low volume on vibrato channel. Just ordered a tube socket for V-4 as pin #7 shows burn marks cant clean.
Does your amp have low power in that channel compared to the other?
If you resolve problem, please post and I will do same.
  • MAKE LOVE NOT WAR
« Reply #18 on: January 27, 2013, 08:34:42 pm »
Hi Cork, Yes,  low volume when tremolo volume is raised. For sure I'll post the results when I find the cause of the issue.
Cheers
Colas
