September 17, 2026, 04:41:15 am
Hoffman Amps Forum image Author Topic: pf value cap from 12AX7 plate to cathode?  (Read 5194 times)
Offline 12AX7
« on: February 06, 2013, 12:44:10 am »
Didn't wanna hijack that other thread about sluckey's  dual preamp marshall. But i had a question about it. I think the 100pf cap on V2A from the plate to cathode is to tame high end, right? if so, what is the difference between that and using a cap across the plate resistor instead? Or IS that plate>cathode for something other than taming high end?
Re: pf value cap from 12AX7 plate to cathode?
« Reply #1 on: February 06, 2013, 03:45:38 am »
They're both doing the same thing, because they are both bypassing the plate and shunting some HF to 'ground' (either via the B+ and thence through the filter caps to ground, or 'more directly' via the cathode)
Offline 12AX7
« Reply #2 on: February 06, 2013, 12:59:26 pm »
Thats what i figured. I guess they sound a bit different which would be the only reason i can see that people don't all just use one way. I think i'll have to try this myself in place of my current parallel plate cap.
