September 16, 2026, 02:10:26 pm
Hoffman Amps Forum image Author Topic: Traynor Custom Reverb trem always "on"  (Read 5114 times)
Offline Cups
« on: February 13, 2013, 12:16:01 pm »
Hi folks
On to another repair. Did a lot of work on this one: replaced reverb tank, recap, reground to galactic ground, individual 1k screen resistors. Added cathode resistor to bright channel and such
Sounds great. And quite quiet. This amp would be a keeper (aren't they all though - especially after you fix 'em)
There's always a throbbing trem sound though and I know I'm being lazy but instead of poking around I thought I'd ask here first. :icon_biggrin:
I know it's bias modulated but I don't get trems enough to know where to start
Thanks in advance guys.
Patrick
Offline Cups
Re: Traynor Custom Reverb trem always "on"
« Reply #2 on: February 13, 2013, 03:14:32 pm »
Both of those schematics show an oscillator setup where you need the footswitch to turn the trem off, just like a Princeton Reverb.
Does turning the Intensity down to 0 not silence the trem?
Offline Cups
« Reply #3 on: February 13, 2013, 04:19:55 pm »
Intensity at 0 there is still a pulse.
I'll try a footswitch.  :think1:
« Reply #4 on: February 14, 2013, 06:17:56 pm »
Do you have a ceiling fan?
Did you re-cap the bias supply? If the cap at the -38V point is lame, trem will leak.
But it may be leaking other ways. Agree that it may be best to kill the trem with the footswitch.
« Reply #5 on: February 14, 2013, 10:34:00 pm »
I suspect the different load impedance seen from the trem/bias point to ground may result in the thumping.
What I mean is You have the resistors going from the common trem/bias point to each grid, which are in parallel with the phase inverter plate loads via the coupling cap.
I wonder if differences in the 100k resistors, coupling caps or the intended difference in the long-tail plate loads keep the two sides of the trem unequal, resulting in failure to cancel at the output stage.
I dunno, cause I've never investigated this situation. Try the stuff PRR mentioned first. I do notice that Fender generally saved bias-vary trem for non-long-tail amps, which makes me wonder...
Offline Cups
« Reply #6 on: February 19, 2013, 08:38:53 pm »
Feel a little silly.
It does need a footswitch. Quiet with a switch. If it was a keeper I'd mod it for a slower pulse but it's fixed and out the door.
Another funny quirk with this amp is the "tall" el34 won't fit in this amp. I guess just a shorter 6ca7 will fit. Do they have a shorter el34??
