September 18, 2026, 08:13:22 pm
Hoffman Amps Forum image Author Topic: Mesa Boogie ; Pots needed  (Read 11460 times)
stratele52
  • Guest
« on: February 23, 2013, 08:02:59 am »
I'm looking for 2 pots for Mesa Boogie Head ,  .50 caliber +
These pots are for Presence and for Reverb . Customer broke the shafts
Can't find these pots on the web. I just find one place in United State but they don't ship in Canada.
Can you help me ?
Thank's
amprepairparts.com/pots.htm  : they don't ship
Here whats I need and they have it ;
POT, MESA BOOGIE, 100K OHM LINEAR, (B100K), SOLDER LUGS, 24mm DIAMETER BODY, LONG "D" TYPE SHAFT, 3/8" BUSHING.  Used in many earlier Mesa Boogie amps, especially their early combos.  This pot has a plastic "D" shaped-shaft.  Original Mesa Boogie part # 591050.  DOES NOT INCLUDE NUT OR WASHER.  IF NEW NUT IS NEEDED, ORDER THE JNUT-38 NUT FOUND IN THIS SECTION
Part #MB-591050
$5.95
POT, MESA BOOGIE, 250K OHM AUDIO, (A250K), SOLDER LUGS, 24mm DIAMETER BODY, LONG "D" TYPE SHAFT, 3/8" BUSHING.  Used in many earlier Mesa Boogie amps, especially their early combos.  This pot has a plastic "D" shaped-shaft.  Original Mesa Boogie part # 591048. DOES NOT INCLUDE NUT OR WASHER.  IF NEW NUT IS NEEDED, ORDER THE JNUT-38 NUT FOUND IN THIS SECTION
Part #MB-591048
$5.95
Offline Geezer
Re: Mesa Boogie ; Pots needed
« Reply #1 on: February 23, 2013, 08:56:25 am »
It looks like a standard 24mm solder lug pot to me, just needs to have a "D" shaft on it.
Mouser, Newark, pretty much anyone will have that pot. Probably a Canadian company that has it, too...... It doesn't have to state it's specifically for a Mesa, just find the correct value, taper, lugs and shaft type and you're done!
G
« Last Edit: February 23, 2013, 08:59:17 am by Geezer »
« Reply #2 on: February 23, 2013, 09:00:06 am »
Can you find what you are looking for here ?
http://www.tubeampdoctor.com/catalog.php?product_search=mesa%20boogie%20pot
they ship in Canada, but, unfortunately shipping price is very high
so you must find it at your side of the pond :sad:
« Reply #3 on: February 23, 2013, 09:12:47 am »
Do the knobs pushed onto a knurled shaft or do they have a setscrew? If setscrew, it's easy to convert a solid shaft into a "D" type shaft.
stratele52
  • Guest
« Reply #4 on: February 23, 2013, 10:14:25 am »
G
No they have not , I checked on ther web site
stratele52
  • Guest
« Reply #5 on: February 23, 2013, 10:21:06 am »
Not set screw , I never saw a D shaft with set screw.  Not knurled too.
To convert , yes easy , but I have to find a "medieum/ long" shaft a with log/ audio pot. This will be my second choice.
For now , I install pots with  round shaft  and screw type knob so my custumer can use his amp. I have time to find the original pots.
Thank's
Offline VMS
« Reply #6 on: February 24, 2013, 06:11:10 am »
Have you asked from your area authorized repair places?
http://www.mesaboogie.com/US/Dealers/rep_select_2.php
stratele52
  • Guest
« Reply #7 on: February 24, 2013, 07:02:53 am »
Not yet but this will be one of my other options .  I'm on this forum to find a place where I can order these part on the web. For now I fix the amp with round shaft pots with screw type knobs I have in stock . So my customer can use his amp . There is no rush for parts
Offline VMS
« Reply #8 on: February 24, 2013, 07:21:45 am »
To narrow your search, according to this place the potentiometer is most likely CTS 450 series pot:
http://www.meinlshop.de/de/mesa-boogie/ersatzteile/elektronische-bauteile/potentiometer/potentiometer-591050/
with 3/4", 7/8" or 1" flat shaft.
http://www.ctscorp.com/components/Datasheets/450sp.pdf
Haven't find online shop yet, but digikey may have the 100k linear pot.
« Last Edit: February 24, 2013, 07:27:47 am by VMS »
stratele52
  • Guest
« Reply #9 on: February 24, 2013, 07:24:03 am »
=591050]http://www.mesaboogie.de/suche.html?tx_solr[q]=591050
Thank's ,
I have data sheet since friday and for linear pot ,yes it is easier to find , but where I can order the 250 K log / audio pot I'll find the 100 k too.
« Last Edit: February 24, 2013, 07:27:28 am by stratele52 »
« Reply #10 on: February 24, 2013, 07:26:58 am »
Do these pots have the correct shaft diameter/length for the original knobs? If so, just file a flat on the shafts.
stratele52
  • Guest
« Reply #11 on: February 24, 2013, 07:30:32 am »
No , too short , I think of that before. I scrap one pot for a test , make a flat shaft.
Offline VMS
« Reply #12 on: February 24, 2013, 07:35:16 am »
If the original pot is otherwise Ok, then you can order any value pot and just change the shaft.
stratele52
  • Guest
« Reply #13 on: February 24, 2013, 02:13:17 pm »
Great idea to order the shafts.
stratele52
  • Guest
« Reply #14 on: February 28, 2013, 06:24:38 am »
Fews days ago a I send a e-mail to CTS asking them if they can send me 2 free sample of molded plastic shaft . They answer to me , yes they will put in mail. Great company. Waiting for the shafts.
My customer , the amp owner, think he could ordered Mesa Boogie pots from USA ,with the help of the business he work. waiting for some news.
stratele52
  • Guest
« Reply #15 on: April 10, 2013, 06:45:48 am »
Receive some shaft fews week ago, I just dismantle pot ; can't replace the shaft ,it is all in one plastic  uit shaft and wiper.
A real joke...
« Reply #16 on: April 10, 2013, 09:34:58 am »
Can't you use a small aluminium pipe (or aluminium duct tape) ad acrylic glue to connect the broken shaft with the new shaft ?
or, can't you find a new pot with round shaft and mold it with a file as to obrain a D shaft ?
« Reply #17 on: April 10, 2013, 09:42:49 am »
Reminds me of the faucet-rebuilding zone at Home Depot.
It's not like I wish we lived in 1974 Soviet Union or anything, but isn't it just great that we have 19 different kinds of pot shafts? We just *have* to have this, right?
