September 15, 2026, 08:34:21 am
Hoffman Amps Forum image Author Topic: Have you ever tweaked a built so many times you feel like re-doing it?  (Read 5238 times)
Offline catnine
  • I am wordy and frustrating EAYOR
My 6V6 P-P build is one I tweaked so many times . When one starts a built you start with the tranny's and the tube sockets and heater wires . Well I do . Then you start with a new eyelet board and insert all the resister and cap leads with the wire leads and bend over the leads and add in the under board leads and with room to work make real nice solder joints . I even might use a filter cap lead and to get it to the best ground point to keep the reservoir cap at a different ground point than the input section I line up the filter caps and run the neg side of a new filter cap under the eyelet board to a spare eyelet then to ground so I don't have to force 4 leads into one eyelet. But then the tweaking comes along to get the sound you want and then you need to cut one of the nice jumpers you made and un-solder and remove all the old solder and some solder joints come out fine and others that are difficult to reach are no longer the nice eyelet with just enough solder where the eyelet was once filled with just a slight dip in the center and now is a taller but shiny little hill.
 I don't have a solder station and even got a smaller tip for my 40 watt weller marksman which came with a huge 1/4" chisel tip so I got the 1/8" screw driver tip thinking it would work great since it has a small dia barrel or heater and it's long enough to reach in tight spots without the fear of melting something near but the damn weller was to hot . I went back to the old unger which had this rather large ceramic heating element and it's marked on the heater 37 1/2 watt 110 VAC and 44 watt at 120VAC yet even with the same size 1/8" screwdriver tip it works perfect . The drawback is the large dia ceramic heater had to be 3/4" dia and is half the length of the entire shank .
 Both the weller and ungar are close to the same wattage and tip size yet one works better , doesn't make sense to me.
 I use a spool or 18AGW with an alligator clip as a heat sink to keep the heat off the filter caps when making changes and even small heat sinks for resisters and small caps just to play it safe . I just feel like making a new eyelet board much smaller so I have more room and going back to the old cloth solid core wire and get new F&T filter caps and start over . It all works fine now . I thing the only things I have not soldered more than once are the heater leads and PT and OT leads . I stuffed a lot of amp into a small 77 fender music master bass amp chassis and used this huge weber 5E3 fiber eyelet board .
 This is what it looked like before I added one more filter cap .
 Now I moved the bias board off the fiber board and placed it between the end of the fiber board and the PT and moved the B+ fuse over to the far left side of the chassis on the inside of the right side near the top of the side centered between the strap bolt holes and mounted the bias board closer to the front of the amp and have it on a tall nylon standoff to keep chassis heat from it. Then moved the reservoir cap over to the eyelets that used to be used for a cathode bias resister and cap , then placed a new 16uf sprague filter cap where the reservoir cap was and added on more dropper . It really looks packed full now. I even shortened the leads between the output sockets and on the PI to V2 . If I made a new eyelet board of the 1/8" hoffman stock I could make the board 1/3 the size and then fit the much smaller F&T filter caps and be able to at least get at the filter cap ground ends and make a new bias board just a bit smaller. Course this will have to wait some time until I find the funds . You can't even see the three resisters for the PI since the sprague caps are so large. Something tells me the weber eyelet board was not designed to use sprague filter caps.
 This is the back view showing the size of the PT and OT .
 If I had room I would use a cap can or the cover and put the caps under the chassis like the BFDR .
« Last Edit: March 06, 2013, 03:21:21 pm by catnine »
Offline G._Hoffman
All of them, so far.
Gabriel
Offline catnine
Gabriel
 I looked at your website . I always wanted to build an acoustic guitar but never did .
 I built close to 15 electrics the last 4 being strats . All I had as far as power tools was a router and cheap durocraft bench top 1/2" drill press and templates I made . The rest was all done with on old 9 inch smoothing plane given to me my my grandfather . two spoke shaves and a block plane and a small block plane with a arched handle for control and rasp files and a few handsaws and later a good jig saw. I cut my fret boards from one thick long section of rosewood . plane one side smooth and mark 3/8" around and cut with the handsaw then plane the other side flat. I had plenty of claps and patience. 12 of these guitars sat for decades  even took them to guitar shops . Then one day the Bay came along and they all sold . I used to go through hardwood planks and a hardwood shop that is now gone and select the wood based on the grain both for the neck and body so if it were a one piece neck and since they didn't have quarter sawn I would get flat sawn so it wouldn't twist and the bodies were all two piece from the same board cut in half and flipped around so the grain was the same on both sides . So far not one of them ever changed .
 I always admired the ones who built the acoustics.
Offline G._Hoffman
Gabriel
I'm mostly doing electrics these days - the acoustics are all my dad.  I've done them, but it's pretty hard to put an acoustic of mine on the wall next to his.  They look as good, but I'm afraid I don't have the sound down the way he does!
Good wood for necks is important.  We had a 1954 Gibson J200 in the shop a while ago that must have had pretty spectacular wood in the neck - the original lacquer was still on the truss rod nut!!!!!!  Almost 60 years, and this is the first time it's needed the neck adjusted.  And it was being played a lot in that time, judging from the fret wear!!
Gabriel
Offline floyd
I've stuffed AB763 Bandmaster circuits in Vibro-Champ chassis'... great sound.. zero noise. But planning is everything.
