September 16, 2026, 04:27:31 am
Hoffman Amps Forum image Author Topic: TA and TU for pcl86 amp question  (Read 5241 times)
« on: March 19, 2013, 02:41:19 pm »
The schematic is this
and the transformers are those of this stereo amp
TA 230VAC 100mA - 13.5V 1A
TU 5k - 4 and 8 ohm
the rectified 230VAC gives near 320V, the schematic say B+ 280v and the pcl86 datasheet say max 250V plate (300V for the ecl86)
http://www.r-type.org/pdfs/pcl86.pdf
http://www.nj7p.info/Common/Tube/SQL/Tube_query.php?Type=6GW8
However I noted there is a big difference in cathode resistor value, the guitar amp 170R the HiFi amp 330R
How you can get to square the circle ?
EDIT: I forgot to say that in the HiFi stereo amp there was also a 5H 100mA 41.2ohm choke who is disposable for the guitar amp
« Last Edit: March 19, 2013, 06:26:01 pm by kagliostro »
Re: TA and TU for pcl86 amp question
« Reply #1 on: March 19, 2013, 06:38:05 pm »
> 320V ... 280v
From 280V to 320V, for the same dissipation, you must use a 1.3 times higher resistor.
The tube levers the cathode resistor to make an equivalent resistor.
So it makes sense to find a larger resistor. 330/180= 1.8 times higher does seem strange.
Is the tube inexpensive? Can you change it yourself? Then don't worry too much.
Build it, use the larger cathode resistor, measure dissipation, and adjust.
http://rationalwiki.org/wiki/Squaring_the_circle
« Reply #2 on: March 20, 2013, 12:42:52 am »
Hi PRR
Many Thanks
Ok I can follow you about the change in value of the resistor because of the higher B+ voltage
where I'm still a bit confused is in relation with the OT primary impedance
I've seen schematics that say to use a 7k OT but the HiFi amp moreover the 322V B+ uses a 5k OT
in which manner this has effects on the circuit with the higher B+
As there is disposable (from the HiFi amp) the choke (5H 100mA 41.2ohm) I think this will help on tamer a bit the B+, there is math that can help to predict which will be an expected voltage drop ?
Or better, can I use the same math used for a 41.2ohm resistor ?
Thanks Again
one other "squared circle" :grin:
http://en.wikipedia.org/wiki/Vitruvian_Man
« Last Edit: March 20, 2013, 01:56:03 am by kagliostro »
« Reply #3 on: March 20, 2013, 08:16:52 pm »
Yes.
A good guess for load impedance is V/I of the tube. For 320V supply, 12W dissipation, about 300V across the tube, 12W/300V= 0.040A max current, and 300V/0.040A= 7,500 ohms. +/-30% is all the same.
« Reply #4 on: March 21, 2013, 01:16:57 am »
Many Thaks Sir
