September 15, 2026, 08:52:17 am
Hoffman Amps Forum image Author Topic: Build a resistor decade box - cheap  (Read 6453 times)
Offline YVRTubeGeek
« on: April 17, 2013, 10:34:23 pm »
This is a PDF of a project I'm working on.  Basically, it's kinda trivial but I think some will find it useful and it's viable because AdaFruit is selling stackable 10-position push up/down switches pretty cheap.  Note that this was written with the lowest-common denominator electronics hobbyist in mind.
Also, in the PDF I say I'm using 1/4W resistors but it turned out that 1/2W were about the same cost at DigiKey so I went with those.
-Arne
« Last Edit: April 17, 2013, 10:36:40 pm by YVRTubeGeek »
Re: Build a resistor decade box - cheap
« Reply #1 on: May 07, 2013, 10:59:01 am »
Cool project!  Love those cool switches.
OTOH, a box stuffed with standard value resistors and/or capacitors is usually very handy, with no pressing need for lots of in-between incremental values.  When that is needed -- like maybe for a bias circuit -- I use a pot wired as a variable resistor for test/design purposes.   Got that idea from Doug's Library Pages.
