September 08, 2026, 06:39:39 pm
Hoffman Amps Forum image Author Topic: 65 Twin Reverb / Now Deluxe Reverb Reissue Hum  (Read 4834 times)
« on: June 19, 2013, 07:04:42 pm »
I replaced my 65 twin reverb burnt out PT with a 65 Deluxe Reverb reissue PT. All under board changes were made to support this transformer with a 5 volt tap for rectifier tube use. Including standby and B+ positioning
I have developed a hum in this amp that increases as the volume is turned up. The plate voltage is  400VDC  @-37 on the grid. The power supply caps have all been changed.
I got a 65 Deluxe reverb reissue PT of Ebay for cheap ($32.00 w/fs). It hums like the PS caps are bad but are new as of yesterday. I have ruled out the bias cap and power tubes as the possible source. All cathode caps are good as are the voltages on them. I removed the reverb transformer source voltage to rule it out, as well as bypassing the choke with a 500r 5watt resistor. I have to test the channel coupling caps yet but at this point i believe i have a bum power transformer with a serious amount of hum. Any thoughts of anything i may be over looking?
« Last Edit: June 19, 2013, 07:11:06 pm by plexi50 »
Re: 65 Twin Reverb / Now Deluxe Reverb Reissue Hum
« Reply #1 on: June 20, 2013, 01:36:54 am »
Hey Plexi,Can an old PT (59years of age) be a source of hum and fizz if it is not well, although still able to pump out the designed volts???
« Reply #2 on: June 20, 2013, 06:54:03 am »
Does it hum on both channels?
« Reply #3 on: June 21, 2013, 07:56:12 am »
Yes both channels. But the Vibrato channel is much louder and is the dominant hummer. Hum is present with volume pots at zero but is quickly amplified with volume rotation.
« Reply #4 on: June 25, 2013, 06:29:43 pm »
I got around to do some more testing today on the PT i bought and it is bad. The heater filament winding is burnt and is black just under the plastic wrapper on this PT. I could feel the PT vibrating with my hand and hear it as well. That will teach me to not buy another reissue PT.
