August 29, 2026, 12:17:51 pm
Hoffman Amps Forum image Author Topic: 1965 Princeton Reverb Trem very weak  (Read 5195 times)
Offline jukelemon
  • It's always in the fingers
« on: July 12, 2013, 09:49:04 am »
Hi all.  Several years ago I built one into a P12N.  It has been such a great amp.  But the Trem never worked right.  Just weak.
I posted a few years back on this and got several good responses.  I cannot find those old posts.  Sorry.
I swapped tubes.  No change.
It is there and I can hear the changes in Speed, but it is just weak.
No loss of power.
It is like the Intensity of the effect is ~10% at full range if that makes sense.
I believe it is photo driven.  I wish I would have built to be bias modulating but...hindsight.
Any ideas?
Juke
Re: 1965 Princeton Reverb Trem very weak
« Reply #1 on: July 12, 2013, 09:56:16 am »
A stock PR is bias trem. Search this forum for weak tremolo.
« Reply #2 on: July 12, 2013, 01:48:39 pm »
First thing to try is swapping the tube that contains the tremolo LFO stage.
Biasing the output stage cooler also helps increase the 'slam'.
« Reply #3 on: July 12, 2013, 03:08:55 pm »
Did you look in Archives?
http://www.el34world.com/Forum/index.php?topic=604.0
Offline jim
« Reply #4 on: July 12, 2013, 03:59:01 pm »
Check the bug in a dark room. It could be leaking too much light. If the rest of the trem circuit is OK you should swap it out for a spare.  Jim
« Reply #5 on: July 12, 2013, 04:32:25 pm »
Check the 25/25 cathode cap pin #3 on the LFO stage
