August 29, 2026, 12:17:49 pm
Hoffman Amps Forum image Author Topic: 5E11 Bright issue  (Read 4625 times)
Offline jukelemon
  • It's always in the fingers
5E11 Bright issue
« on: July 14, 2013, 03:29:36 pm »
http://www.webphix.com/schematic%20heaven/www.schematicheaven.com/fenderamps/vibrolux_5e11_schem.pdf
The 500pf cap between the Tone and Volume...
Does that control the brightness of the tone - serve as a low pass filter?
I have one and the amp is way too bright.  Tone set to 1 is like 6 on all my other amps.  Past 5, the Tone knob is not useable.
Thank you.
Re: 5E11 Bright issue
« Reply #1 on: July 15, 2013, 12:32:43 am »
I wonder if the 0.005u at the other end is kaput.
Offline jukelemon
« Reply #2 on: July 15, 2013, 07:52:39 am »
I can check that too.
I subbed in a 1000p for that 500.  Really no change.
Does the .005uf serve as the low pass filter?
« Reply #3 on: July 15, 2013, 11:49:03 am »
When you turn it one way, the 0.005 shunts all the highs to ground, "dull". (Does that happen??)
When turned the other way, the 500 shunts highs around the volume control (so no effect if you play at "10"), "bright".
In the middle should be halfway between dull and bright.
As long as you are subbing stuff-- snip the wire from top of Volume pot to wiper of Tone pot. This "should" be a Flat Amp, balanced bass and treble. That's normally not best for guitar, it's more like playing through a hi-fi or DI to flat studio monitor.
Speaker is always important. Some are just bright. If the voicecoil has got stuck, the bass won't happen but sometimes the shrill gets out fine.
If what you get no-tone-pot is very shrill, and it isn't the speaker, find what's gone wrong in the amp. If it is 50 years old, a 0.05 coupling cap may have faded-away to 0.0005. Or a 470K grid resistor may have drifted to 50K. If a new-build, maybe your helper passed you a wrong-value cap or resistor.
Offline jukelemon
« Reply #4 on: July 15, 2013, 12:32:19 pm »
Hi PRR.
No on the 1st Question.  There seems to be no shunting on the .005 side.  At least very little.  I bet that is the culprit.
I need to pull it an make sure the value is right.
There is definitely no dull on this amp.  It is bright to real bright.
It is a homebuilt.
« Reply #5 on: July 15, 2013, 01:02:48 pm »
There seems to be no shunting on the .005 side.  ...
What do the markings on the cap say?
