August 29, 2026, 12:18:42 pm
Hoffman Amps Forum image Author Topic: Fender Deluxe Reverb with Vibrato problems  (Read 8724 times)
Offline Jack1962
  • I love AMPS, Tube or SS
    • Latham Electronic Systems
« on: July 18, 2013, 11:08:47 am »
my question is , will replacing the 6V6 tubes with 6L6's cause problems with the vibrato
Offline phsyconoodler
Re: Fender Deluxe Reverb with Vibrato problems
« Reply #1 on: July 18, 2013, 11:29:08 am »
No,it shouldn't.
  I'm assuming you have  a trem problem and the only change you made was swapping tube types?
The bias circuit does have a tap going to the 2.2meg resistor near the roach, but unless the tubes were wayyyyy off in bias then I can't them causing an issue with the trem.
« Last Edit: July 18, 2013, 11:32:45 am by phsyconoodler »
« Reply #2 on: July 18, 2013, 11:47:08 am »
If it is Bias Vary Tremolo it will.  If it has the roach, is should not.
« Reply #3 on: July 18, 2013, 12:16:29 pm »
Bingo. And the DR uses a roach.
Offline Jack1962
« Reply #4 on: July 18, 2013, 01:38:33 pm »
well I didn't install the tubes it came to me that way , it is biased correctly for a 50 watt amp but the transformer is the original DR transformer . the vibrato works only when the intensity is turned to 10 , however the rate/speed control works perfectly , that is what I'm having trouble getting my head around .
« Reply #5 on: July 18, 2013, 09:29:37 pm »
I just changed out a roach on a 1978 Deluxe Reverb with the pull boost reverb. I thought that was the reason for the lack of thump the vibrato had. It wasnt the roach in my case. Then i looked at the later silverface schemo and the vibrato cathode used a 5uf cap (AB868) instead of the 25uf cap used in the AB763 circuit. I removed the 5uf and put in a 25uf. Deeper and more alive vibrato. Not sure if this is your case though
« Last Edit: July 18, 2013, 09:34:44 pm by plexi50 »
Offline Jack1962
« Reply #6 on: July 19, 2013, 06:10:04 am »
yeah I changed the roach too , no change , this is a AB763 , I'm thinking it is probably that 50k-ra intensity pot . nothing else seems to read bad , but I am using my bad ass Harbor Freight DMM lol
« Reply #7 on: July 19, 2013, 07:56:04 am »
Have you checked or tested the cathode cap for the vibrato?
I bought a cap tester a while back. Indispensable tool. Cheap too. You would be surprised when testing caps just how many new capacitors are beyond there rated value. This is the one i have in the pic. Those white Mallory 25uf cathode caps in my deluxe reverb were reading any where from 38-88uf.
« Last Edit: July 19, 2013, 07:59:01 am by plexi50 »
Offline Jack1962
« Reply #8 on: July 20, 2013, 06:30:25 am »
no I haven't , but I will now lol  I bought that same meter lol
